Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Products > Floor drain calculations
Thread Tools Display Modes
Old 03-17-2014, 02:42 PM   #1
Liked 2 Times on 1 Posts
Default Floor drain calculations
To calculate the GPM capacity of a floor drain, I found the following equation:
Q = 448.2 Cd A 2gh where Q = Flow Rate (Gallons per Minute)
Cd = Discharge Coefficient (Typically 0.6)
A = Open Area of Grate (ft2)
g = Acceleration (32.2 ft/s2)
h = Head Above the Floor (ft)
What is meant by head above the floor for h? the floor drain is flush with the floor.
britkath is offline
Old 03-17-2014, 11:14 PM   #2
Liked 236 Times on 187 Posts
Likes Given: 165
If I'm not mistaken the head above the floor is the amount of water buildup on the floor. Engineering mumbo jumbo.
IFIXH20 is offline
Old 10-11-2014, 03:23 PM   #3
Get a code book,each size has a dfu (drainage fixtures units)which is how you size it.
wyrickmech is offline
Field line options and calculations Zanne Septic Tanks 16 04-12-2013 01:07 AM
Garage Floor Drain jpm6621 General Plumbing Help 4 09-12-2012 04:13 PM
Floor drain backing up Swenny Drain and Sewer Cleaning 3 02-13-2012 05:07 PM
Floor drain to shower drain conversion gooch43 General Plumbing Help 1 11-22-2011 12:51 AM
What's up with this floor drain? josh4377 General Plumbing Help 9 06-04-2011 08:16 PM
Newest Threads
