Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Update on my leaky toilet woes
Thread Tools Display Modes
Old 03-01-2014, 11:31 PM   #1
newbie666
Liked 1 Times on 1 Posts
Default Update on my leaky toilet woes
Its been about a month and yet again it leaked a bit today, cleaned it up and put some pieces of toilet paper to make sure it had stopped leaking. Noticed nuts holding down toilet were hand loose so I tightened them. This current installation(s) were good for a month then it leaked. I imagine if there was a crack somewhere it would leak slowly and constantly as I have had toilet paper around the base to detect leaks.
If you look at my pics the flange bolts they slide into a notch in the lead liner is that correct? Looks like lead liner was pulled up bit to allow bolts to slide in and when liner is flat it holds it in place. Is it normal to be able wiggle bots a bit? Should I use a plastic washer underneath the brass ones in the pic? Also lead flange isn't smooth like a plastic one, it does have some irregularites and I don't see any cracks in it.
Should I use shims? At the front and back of the toilet there is no gap to speak of. In the middle around where the bolt holes there is a gap.
I'm at a loss, tried 2 toilets, wax ring on flange first, wax ring on toilet first. I guess I should have hired a plumber from the get go and had it done "right".
newbie666 is offline
Old 03-01-2014, 11:33 PM   #2
newbie666
Here is how much of a shim I can slide in underneath the base of the toilet where the bolts would be. I marked it off with green tape.
Old 03-02-2014, 02:33 PM   #3
Matt30
Liked 734 Times on 557 Posts
Likes Given: 199
Is the flange itself secure?
Matt30 is offline
Old 03-07-2014, 04:12 PM   #4
SHR
Liked 282 Times on 214 Posts
Likes Given: 789
Usually traditional wax seals work very well, but since you seem to be having problems with this installation, do yourself a favor and use a Sani seal waxless toilet seal. It will eliminate any issues with your seal at the flange.
http://www.amazon.com/Sani-Seal-Llc-...ords=sani+seal
SHR is offline
Old 03-07-2014, 04:17 PM   #5
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
What he has is a lead bend. Sani-seal won't work.
John
johnjh2o is offline
Zanne Likes This
Old 03-07-2014, 11:50 PM   #6
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
I keep looking at that picture, and thinking that I wouldn't want to try and get a proper seal against that flange. Maybe the picture isn't doing it justice, but there doesn't seem to be much there.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Zanne Likes This
Old 03-11-2014, 02:08 AM   #7
jdc
Plumbing Technologist
jdc's Avatar
Liked 6 Times on 5 Posts
Likes Given: 4
I agree with phish. Doesnt seem to be much there. In addition, looks low to my eye.
jdc is offline
Old 03-11-2014, 04:31 PM   #8
SHR
Likes Given: 789
Quote:
Install a replacement stainless steel flange screwed to the subfloor and then the toilet can be installed solidly as normal. An experienced plumber may want to solder on a brass flange but even most plumbers would just screw on the stainless steel ring.
http://www.homedepot.com/p/Sioux-Chi...6-MR/202274075
SHR is offline
Old 03-11-2014, 08:31 PM   #9
plumbdrum
Banned
Liked 17 Times on 16 Posts
Is the flange lower than your finish floor?
Sent from my iPhone using Plumbing Forum
plumbdrum is offline
Shower/Tub Trim Kit Update jessb_55 General Plumbing Help 5 10-20-2013 11:13 PM
flammable vapor sensor woes NickW General Plumbing Help 2 08-07-2013 12:33 AM
Water Filter Installation Woes daniell General Plumbing Help 9 08-03-2011 11:12 PM
Update: Line backed up again, now what? arsenik General Plumbing Help 4 07-23-2011 06:35 PM
Water heater relief valve woes everyman General Plumbing Help 8 11-01-2010 07:13 PM
Newest Threads
