Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Back water valve? or snaking?
Thread Tools Display Modes
Old 02-11-2014, 09:21 PM   #1
ch00ver
Default Back water valve? or snaking?
Hello all, new to the forum would love some discussion on a question.
My basement floor drain is backing up. The municipality I live in has a program to install a back water valve so I have ordered the package. However, I'm not sure this is the issue.
I get a puddle around the drain and the issue started during a heavy storm which leads me to believe its a backflow issue. BUT, I'm thinking this may be coincidence as it usually reoccurs after doing laundry or draining the upstairs tub.
There is also a bit of an odour coming from the drain. My question, how do I know if the drain is clogged, or if it requires a back flow valve? Is the answer simply to get the drain snaked and see if the issue resolves?
Thanks.
ch00ver is offline
Old 02-14-2014, 02:12 AM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
Snake the drain for sure. I'd highly suggest hiring a pro because those snakes have been know to break limbs on inexperienced users. I'm willing to bet that that is your issue you have a blockage in your sewer line. Backwater valves ONLY protect you if the city backs up. Ex. Your having issues in your line but then say the city sewer gets overloaded or plugged then water will back up into adjoining properties. That normally open backwater valve will then close and protect your home.
stevemachine is offline
Old 02-15-2014, 01:38 AM   #3
ch00ver
Quote:
Thanks, stevemachine.
Had it snaked today, big wad of what looked like lint from the laundry machine had been collected. Just moved in to the house, and it was built in the '40s. Quite the list of things to do, which now includes some work to update the basement plumbing to ensure smooth running in the future.
ch00ver is offline
Old 02-18-2014, 11:48 PM   #4
stevemachine
Likes Given: 97
No problem thanks for letting us know the result and glad it's been cleared
Sent from my iPod touch using Plumbing Forum
Old 03-19-2014, 02:27 PM   #5
plumbdrum
Banned
Liked 17 Times on 16 Posts
Also your backwater valve should be installed on the branch of the floor drain or any other basement plumbing.If you had no basement plumbing then it may be installed on the main with proper accessibility .
Sent from my iPhone using Plumbing Forum
plumbdrum is offline
Back-to-back toilets clogging (sewer line replaced two weeks ago) ockola Toilets and Sinks 4 02-04-2014 03:50 PM
How to plumb back to back double sinks edtuck General Plumbing Help 0 05-22-2012 04:41 AM
Back Water Valve Anthony187 Plumbing Products 3 08-15-2011 04:14 AM
Snaking water lines? Greencreekproperties Pumps and Wells 1 06-28-2011 03:47 AM
Water heater pressure and a back flow valve joeparocks General Plumbing Help 9 11-19-2010 06:31 PM
Newest Threads
