Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > off-set Closet Flange
Thread Tools Display Modes
Old 02-05-2014, 01:56 AM   #1
Handley
Default off-set Closet Flange
I need help! do they make an off-set closet flange that fits into the existing closet flange. I need to move my toilet away from the wall, the tank does not fit properly and leaks because of the closet flange being located to close to the wall. Any help would be appreciated.
Handley is offline
Old 02-05-2014, 02:01 AM   #2
phishfood
Administrator
Liked 943 Times on 759 Posts
Likes Given: 1684
No, they do not, for the simple reason that the center of the offset flange has to move in the direction of the offset, both the center of the bolts and the center of the opening for the waste.
Many toilet manufacturers make a 10" rough tank that will fit in your type of situation.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 02-05-2014, 02:10 AM   #3
Handley
Thank you for your help, I am having a hard time getting under the house and trying replace the closet flange. I just put a new floor and new walls up in the bathroom. But what good is new bathroom when you have no toilet. Handley
Handley is offline
Old 02-11-2014, 04:55 AM   #4
DIYeverything
Do It Myself And Save
Liked 1 Times on 1 Posts
If the toilet fit before, why not now?
DIYeverything is offline
Old 02-11-2014, 12:33 PM   #5
oh_io
oh_io's Avatar
Liked 5 Times on 5 Posts
Likes Given: 3
Quote:
I would guess that the new wall board he put up is thicker, or over laid onto the existing wall making the space between finished wall and flange smaller.
oh_io is offline
Closet flange problem Dogstar General Plumbing Help 1 04-15-2012 08:14 PM
Quik-Fix Closet Flange Extension Kit ak99588 Plumbing Products 2 03-27-2012 12:26 AM
Need Help-- New Closet Flange to Old Iron Pipe fireduck Toilets and Sinks 4 11-28-2011 01:54 PM
closet flange Dave43026 Toilets and Sinks 1 11-07-2011 02:24 PM
Quickset Closet Flange elengineerio Toilets and Sinks 1 08-20-2011 06:26 PM
Newest Threads
