Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > IS there a glue for ABS cracks?
Thread Tools Display Modes
Old 12-25-2013, 07:21 PM   #1
djdenali
Default IS there a glue for ABS cracks?
I tried to attach a photo of a crack I have in an ABS connection. The crack is just above a T-joint. So, to repair, it looks like I'd have to replace the T-joint itself, PLUS all three connections, and then all the couplings on the OTHER end of the pipes leaving the T-joint. It there a a simple glue to repair a somewhat minor crack in ABS piping?
djdenali is offline
Old 12-25-2013, 07:25 PM   #2
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
They sell a few different patch work items but a proper fix will be to replace the fitting to a good section of pipe and yes they make a glue specifically for abs.
Chris is offline
Old 12-25-2013, 11:45 PM   #3
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
Are you sure that's ABS it looks like cast iron to me.
John
johnjh2o is offline
Old 12-27-2013, 01:51 AM   #4
jdc
Plumbing Technologist
jdc's Avatar
Liked 6 Times on 5 Posts
Likes Given: 4
Agreed. That looks like cast iron and not a minor crack. Either way, the only proper fix is to cut it out and replace it.
jdc is offline
Old 12-27-2013, 07:01 PM   #5
djdenali
Thanks for the advice. I'm 99.9% sure it's ABS as everything else connected is. But now you have me wondering. So, I'll go check...
thanks.
djdenali is offline
Old 12-27-2013, 08:19 PM   #6
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Quote:
thanks.
ABS doesn't rust and the hubs on the fittings are much smaller.
John
johnjh2o is offline
IFIXH20 Likes This
Old 12-27-2013, 11:28 PM   #7
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
And the crack pattern looks like I would expect to see with cast iron, not plastic. Though I am not all that experienced with ABS.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 12-28-2013, 12:24 AM   #8
Chris
Administrator
Chris's Avatar
Likes Given: 67
I've seen cracks like that on abs a few times.
Chris is offline
phishfood Likes This
Old 12-28-2013, 01:47 AM   #9
havasu
Administrator
havasu's Avatar
Liked 1130 Times on 922 Posts
Likes Given: 351
The suspense is killing me!
havasu is offline
Old 01-14-2014, 08:41 PM   #10
djdenali
Sorry for the long response...notice the 'abs' clearly written on the black pipe...Also, the keen eye will notice a brown deck perpendicular to this pipe--spray painted...brown specs can indeed look like rust from a lousy photo. Thanks for keeping me honest.
djdenali is offline
Can I glue a PVC flange to a cast iron sewer pipe? Gastronomique Toilets and Sinks 4 01-04-2012 10:39 PM
Newest Threads
