Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Hot water heater problems
Thread Tools Display Modes
Old 12-19-2013, 05:23 PM   #1
phoenix
Liked 1 Times on 1 Posts
Default Hot water heater problems
Hello all,
I've got an AOSmith 40 gallon gas hot water heater, approx 2 1/2 years old in a new construction house.
Lately the pressure relief valve on the side has been discharging close to 2 gallons a day, not a constant drip so i assume it's only discharging when the pressure gets too high.
i've got the temperature in the tank set lower than the factory setting and usually don't have more than one hot water using fixture going at the same time (ie dishwasher, shower, washing machine)
Do i have a bad pressure relief valve?
Do i have a bad expansion tank?
is this functioning as intended and should i just install a drain?
any help would be greatly appreciated
thanks in advance
-Jason
phoenix is offline
Old 12-19-2013, 10:08 PM   #2
countryboy26047
countryboy26047's Avatar
Liked 7 Times on 6 Posts
Likes Given: 11
I've never known of a PRV releasing any amount of water unless it's either A) As you said, a bad valve, or B) possibly a bad t-stat controller causing the water to get hotter than the actual set-point?
God Bless our troops and their families!
countryboy26047 is offline
Old 12-20-2013, 01:04 AM   #3
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
My first guess is that the expansion tank you mentioned has gone bad. With the house main shut off and water pressure drained, use a tire gauge to check the air pressure in it.
T&P valves do go bad, but it is not all that common.
It is also possible that a thermostat is sticking on sometimes, but the red ECO switch should be cutting out if that is the case.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
People Like This
Old 12-20-2013, 10:38 AM   #4
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
I agree with phish and it should be added that when you check the pressure from the schrader valve on the expansion tank if you get water from the valve, not air, then the bladder is definitely ruined. If this is the case, be alert when turning the water back on. Little pieces of the disintegrated bladder may clog the schrader valve and water will squirt out of it. Don't panic. You can match up the same size of expansion tank (there are usually two common sizes) at a home improvement or hardware store.
Also check the house pressure with a gauge. The expansion tank may need to have air pressure added to equal the house pressure. They come pre-charged with air @ 20 psi or 40 psi.
Caduceus is offline
Old 12-20-2013, 03:17 PM   #5
phoenix
Thanks for the replies guys,
I secured the main water to the house and started draining the pressure
using a tire pressure gauge on the valve at the bottom i was unable to activate it while under pressure
water pressure partly drained i got a reading of around 24psi
when water pressure was fully drained the tire gauge read 0psi
the tank states it has a pre-charged pressure of 20, a max charged pressure of 80, and a working charge pressure (with water) of 150
should i be getting a zero reading with the home water pressure drained? also no water came out while performing the check
thanks!
phoenix is offline
Old 12-21-2013, 02:34 AM   #6
phishfood
Administrator
Likes Given: 1739
No, it should still have some pressure in it. You can use a tire pump to bring it back up to 40 lbs, but I am thinking that it will loose it's charge again sometime soon. Try soapy water sprayed on the air pressure valve where you checked the pressure and see if you get air bubbles after you re pressurize it.
Old 01-05-2014, 02:48 PM   #7
phoenix
Quote:
thanks Phish,
I was able to re-pressurize it to 40, will check to see in a few days how the pressure is holding and obviously if i don't see water coming out of the pressure relief on the hot water heater i guess that was the problem
thanks for all the help, i appreciate it!
-Jason
phoenix is offline
Old 01-10-2014, 06:54 PM   #8
phoenix
well its been almost a week now and it's stayed bone dry so i guess that was indeed the issue.
thanks again for all the help!
phoenix is offline
Caduceus Likes This
hot water problems ben_fishn Water Heaters and Softeners 7 12-08-2013 04:34 AM
Water heater feed pipe shot. and now i have to replace my whole heater. chucksrt Water Heaters and Softeners 1 05-20-2013 01:14 AM
Water heater connection to boiler domestic hot water coil gillric Water Heaters and Softeners 2 11-11-2011 12:16 PM
Water Heater Problems raji1980 General Plumbing Help 5 10-28-2010 08:35 PM
Newest Threads
