Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Shower mixing valve piping
Thread Tools Display Modes
Old 12-18-2013, 01:06 PM   #1
Default Shower mixing valve piping
During my remodel I uncovered the shower wall with the existing mixing valve. As you can see in the picture the line entering the valve on the right tee's off and jumps from 1/2 to 3/4" or 1" goes up about a foot and then is capped off. Is there a reason for this? My first thought was that the contractor didn't have a 1/2" elbow and then just stuck this in the arrangement?
Jayman is offline
Old 12-18-2013, 02:25 PM   #2
johnjh2o's Avatar
Liked 731 Times on 555 Posts
Likes Given: 625
That is a hammer arrester. What I don't understand is why there isn't one on the hot.
johnjh2o is offline
Old 12-18-2013, 03:13 PM   #3
I am installing a modern thermostatic mixing valve to replace this one. Its an externally mounted mixer i.e. not in the wall. Would it be appropriate to install this way on both the hot and the cold? Thank you
Jayman is offline
Old 12-19-2013, 01:10 AM   #4
Liked 966 Times on 776 Posts
Likes Given: 1739
No, those field manufactured shock arrestors don't do any good after awhile. The air above the water is slowly absorbed into the pressurized water. If you want to install shock arrestors, buy the factory made ones with piston seals that have a gas charge in them.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Looking at Honeywell mixing valve PDubs Water Heaters and Softeners 17 01-24-2012 04:41 AM
Mixing valve not getting hot enough Web64 Showers and Tubs 1 12-05-2011 06:56 PM
ID a Shower mixing valve? logdy General Plumbing Help 1 08-05-2011 11:52 AM
Mixing Valve question warrenbrown General Plumbing Help 3 05-03-2011 10:38 PM
installing shower mixing valve and knob stevespens Showers and Tubs 2 02-03-2011 06:32 PM
Newest Threads
