Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Freestanding Tub Filler Faucet Install
Thread Tools Display Modes
Old 12-17-2013, 01:18 AM   #1
Jayman
Default Freestanding Tub Filler Faucet Install
I am remodeling my master bath and am installing a tub with a "Freestanding" Tub Filler. The one I purchased has 1/2" SS hoses that penetrate the base by a inch or so. The manufacturer does not include instruction for install. I am installing this on a concrete slab, my home is plumbed in CPVC. Any suggestions on how to plumb this up would be appreciated!
Jayman is offline
Old 12-18-2013, 12:45 AM   #2
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
If you are saying that the SS hoses come out of the bottom of the freestanding faucet, than the concrete needs to be broken up, walls need to be cut open, and supply lines ran over to the future location of the faucet.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
johnjh2o Likes This
Old 12-18-2013, 01:00 PM   #3
Jayman
Default Tub Filler piping strategy
Yes, I'm aware I need to break concrete. Attached is the pic from my demo. The two 1/2 lines coming from my slab are the supply line. The circle just in front of them are where the filler will be anchored. My first thought is to breakout just deep enough to hide the lines, accommodate tile etc. and then use 1/2" drop ear elbows to anchor them and turn up. Then I can insert a nipple so that they can be attached to the existing tub filler hoses. Any thoughts on a better strategy?? Thanks
Jayman is offline
Old 02-17-2014, 11:12 PM   #4
rpmbaja
Default tub filler install into slab? Help
I am trying to do the same thing. Would you share with me your end fix. I haven't bought the floor mounted tub filler yet but I do have the tub. I have a concrete slab with the plumbing open in the walls, new construction. Thanks so much for any help!
Terry
rpmbaja is offline
Old 02-18-2014, 03:41 PM   #5
Jayman
I ended up having to build a small box for my tub filler to sit on top and tile over it. This allowed me a small space to make my connections below. It was very much a trial and error project. Needless to say it would have been a breeze if I had a wooden sub-floor and had complete access to the piping.
My tub filler was basically just long pipe with two hoses coming out the bottom with almost no flexibility and almost no instructions. Not much for my $600.00 that's for sure. When you are looking for a filler see if you can view the instructions for install, how do the pipes/hoses exit the unit. Basically a general feel for how this thing is going to have to be installed. My 2 cents...
Jayman is offline
Old 02-19-2014, 03:21 PM   #6
rpmbaja
Thanks for the reply, we ended up at the same conclusion. One question does your unit feel a wobbly? When I installed the last one into sub floor properly the unit would move when you grasped the handheld. The faucet part is solid brass but the long tub part is thin and perhaps cheap. Did yours do the same.
Thanks!
rpmbaja is offline
Old 02-20-2014, 12:44 AM   #7
phishfood
Administrator
Likes Given: 1739
I just installed a very high end, heavy one earlier this week. While I wouldn't call it wobbly, it does have a bit of movement at the control/spout height.
Old 02-20-2014, 03:43 PM   #8
Jayman
No mine is anchored quit well so its solid. It has a SS mounting plate that I anchored to my homemade box. In the end however the unit had an internal leak and the distributor is exchanging it, no questions asked...Thank God. I did speak with one of their staff plumbers after the fact and he told me that typically if someone where installing one of these on a slab, they would actually create a space within their slab where the lines could connect, a shut-off valve could be installed etc. A little late for me...
Jayman is offline
Old 09-13-2014, 01:20 PM   #9
chastylr
I am preparing for to replace a deck mounted tub with a cast iron free standing tub. The drain will need to be relocated in the concrete slab and hot and cold water supply lines will need to be run in the slab. Since the spacing between the water lines and the drain must be exact, I have built a template out of hardibacker and attached drop ear elbows for the water supply to a copper bar that I threaded for the elbows and attached to the hardibacker board. Once I find out the diameter of the new drain, I will use a hole saw to cutout the template where it will slide over the drain. Hopefully, this will result in correct spacing once the template is grouted over. Once the tub is in place, a connecting rod will run between the riser tubes and the back of the over-flow drain (see picture).
I have discussed this with the plumber that will do the job for me and he was concerned about the soldered connection below the slab. I was thinking about having the copper supply lines brazed to the copper elbows. Any thoughts on this? Prior to grouting the template in the concrete slab, I plan to place short lengths of 3" PVC over each of the elbows so the riser tubes can be replaced if needed. The PVC will be trimmed off level with the concrete and tiled over.
Also, I will have the plumber install shut-off valves where the water lines originate under a cabinet.
Any thoughts/comments on this plan?
chastylr is offline
Old 09-13-2014, 01:59 PM   #10
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Why are you making a template, Your plumber should be able to do the job per manufacturer spec.
IFIXH20 is offline
roman tub faucet install kmfdm242 Showers and Tubs 5 12-16-2011 02:55 PM
Height of freestanding tub filler?? haust Showers and Tubs 6 07-03-2011 09:27 PM
Freestanding bathtub drain question sorairo General Plumbing Help 7 06-19-2011 02:35 AM
Faucet Install Help! jsmithe2010 General Plumbing Help 6 09-19-2010 04:07 AM
Cheap tub filler faucet broken need help. bradyman1 Showers and Tubs 7 09-07-2010 07:23 PM
Newest Threads
