Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Help Removing/Changing Cast Iron Shower Drain Flange
Thread Tools Display Modes
Old 12-14-2013, 04:40 PM   #1
applejack
Default Help Removing/Changing Cast Iron Shower Drain Flange
We are redoing the master shower in our newly moved into 1964 built house thanks to a shower pan leak. We've already ripped up everything down to the slab and have come across this drain flange that I don't know what to do with. We are planning to use a "ShowerSlope" by Custom Building Products for the pan and it is supposed to come with a new drain assembly but I believe the existing drain pipe is too tall for it to be flush.
What needs to be done to the old drain so that the new one will fit with our pan and not leak?
I have attached photos of what we're dealing with. Any help or advice would be greatly appreciated. We are a fairly decent DIY couple so if we can do this ourselves it would really help our already surpassed budget.
Thanks!
applejack is offline
Old 12-15-2013, 12:44 PM   #2
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
If you have gone that far why not break up the floor and remove as much of the cast iron as possible or at least remove the cast iron P-trap.
IFIXH20 is offline
Old 12-16-2013, 05:20 PM   #3
applejack
Well, I really hope all that isn't necessary just to get the new drain on. As I said, we've already gone way over budget for the house and now we're having to go back and pay to fix things that were already paid for.
Old 12-16-2013, 07:22 PM   #4
johnjh2o
johnjh2o's Avatar
Liked 707 Times on 539 Posts
Likes Given: 594
Do as IFIXH2O suggested. If you don't do a proper job know it will cost you even more to repair it after the shower is finished.
John
johnjh2o is offline
phishfood Likes This
Cast iron shower drain rgrinde Showers and Tubs 8 04-09-2013 05:34 PM
Having trouble removing a shower drain (cast iron) swimmingmullet Showers and Tubs 4 02-20-2013 08:32 AM
Cast Iron shower drain help atckdbydax Showers and Tubs 3 09-19-2012 11:25 PM
Changing a copper connecter to a cast iron stack nhilo32 General Plumbing Help 25 06-04-2012 12:53 PM
How do I replace a cast iron flange? catpace Toilets and Sinks 2 07-01-2010 02:13 PM
Newest Threads
