Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > running out of ideas, kitchen sink clog
Thread Tools Display Modes
Old 12-09-2013, 02:28 PM   #1
jdrain
Liked 1 Times on 1 Posts
Default running out of ideas, kitchen sink clog
I have a 1 basin kitchen sink that's clogged.
hooked to a dishwasher.
I had the main line cleaned by roto rooter about 3 months ago.
All other drains work properly and flush...no backup at basement floor drain....all is well.
if i run water, it starts to fill up the disposal and overflow back into the sink after running the water for about 15-20 seconds.
p-trap is clean and it seems the garbage disposal is clean.
I have removed all pvc from p-trap, and past p-trap to where the pvc runs into the wall to the main drain.
this is where the clog seems to be as i ran draino into this line and it backed up.
ran a 15 ft snake all the way into the pipe several times. It did not feel like there were any obstructions
WHen i remove it , there is no debris on the end but a little black sludge.
What could be causing this blockage?
Am I missing something?
curious....if I can get a snake 15ft into the pipe, why can i turn the water on and have it overflowing in 15 seconds? Seems like it would need to take longer to backup if there's a minimum of 15 feet of pipe to fill first.
Could the dishwasher have something to do with this?
I haven't ran it as I'm worried of overflow and backup.
I saw this clogbuster gadget at ace hardware, is that a good tool to try?
any of help is greatly appreciated.
thanks
jdrain is offline
Old 12-09-2013, 02:56 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1109 Times on 901 Posts
Likes Given: 327
You need to cal Roto Rooter back, and tell them you again have a clog in the main line. I know they offer a warranty on all their work, but don't know for how long. And please let them know you used Drano.
havasu is offline
Zanne Likes This
Old 12-09-2013, 03:19 PM   #3
jdrain
if there was a clog in the main line, would i not get backups anytime i used other drains or flushed the toilets?
jdrain is offline
Old 12-09-2013, 04:54 PM   #4
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
The branch drain line to the kitchen sink needs to be snaked.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 12-09-2013, 05:35 PM   #5
jdrain
hey Phishfood,
to clarify, is the branch drain line the drain line i'm snaking?
past the kitchen sink p-trap that heads to the main line in the basement?
just want to make sure.
I'd rather tackle this myself and not bring roto rooter back as they made a complete mess of my house when they were here.
they tracked debris all over the place
jdrain is offline
Old 12-10-2013, 12:28 AM   #6
phishfood
Administrator
Likes Given: 1739
Yes, that is the kitchen branch line.
To do a proper snaking job, you will need a power snake with the proper sized cable, a couple of different sized heads (one of those just under the inner diameter of the pipe), a method of running water through the line while you are snaking it, and the know how to run the snake in a way that does a good job of cleaning the line and keeps you from getting hurt.
For drain cleaning, you will usually be ahead to have a professional in. Find a local company that specializes in drain cleaning. A real professional will not leave a mess behind them, I go to great lengths to keep my customer's house clean. Not to say that there are no dedicated professionals working for RR, there probably are, but they have a rather bad name in the trade.
Zanne Likes This
Old 12-10-2013, 01:46 AM   #7
jdrain
Got another problem...
I was able to free the clog with a longer, 25ft snake....running hot water thru it now...thanks for the help and advice, it helped me solve my first problem!!
But I noticed I have a small leak coming from the garbage disposal (see attached pic)
I have this silicone sealant...will it possibly seal that slow leak?
http://www.gatzies.com/p-57319-ge-98...ulk-clear.aspx
If not, would plumber's putty seal it?
Looks like I'll have to go all the way around it because with this being a 2 piece design, if I just patch the small leak, it'll probably just worm it's way over to another area and drip down.
jdrain is offline
Old 12-11-2013, 02:19 PM   #8
Mr_David
Easily Amused
Mr_David's Avatar
Liked 852 Times on 693 Posts
Likes Given: 568
No! putty and silicon will not seal that leak. You are correct it will just worm it's way around. Time for a new disposal.
a.k.a. Krazedav
Mr_David is offline
Kitchen Sink Clog Surprise artworksmetal Drain and Sewer Cleaning 14 05-28-2013 07:51 PM
Kitchen sink running out roof overflow scott Drain and Sewer Cleaning 16 01-21-2012 12:17 AM
wash machine drain clog & kitchen sink... UncleBen Drain and Sewer Cleaning 4 11-07-2011 12:07 AM
Sink clog too far to snake! Biller Drain and Sewer Cleaning 9 08-17-2011 07:09 PM
EZ way to clear slow running bathroom sink drains without a wire snake. 5shot Drain and Sewer Cleaning 12 05-15-2011 01:50 AM
Newest Threads
