Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Leaks after new wax ring(s)
Thread Tools Display Modes
Old 11-27-2013, 02:01 PM   #1
newbie666
Liked 1 Times on 1 Posts
Default Leaks after new wax ring(s)
I have recently installed a new 1 pc toilet and have had some slow leaking issues a day or 2 after the install. The leaks were in different places (see Pics) so I assume I have done something wrong with the install. Also I have tried a regular wax ring and one that is 40% thicker. The pictures are in the order of my attempts. Last pic is one of my flange. Its an uberhaus 1pcs dual flush unit if that helps. The first 2 pics it kind of leaked on and off but very slowly as the saturation in the tissue took 30min to an hour. The last pic it was good for a day and when it did leak it leaked a lot faster. Saturation took minutes.
newbie666 is offline
Old 11-27-2013, 03:06 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1012 Times on 818 Posts
Likes Given: 265
Are you using the wax ring with the black cone on it? I personally like them because it allows for better seating and lowers the chance that I will end up with a leak.
havasu is offline
Old 11-27-2013, 03:32 PM   #3
newbie666
I should add the first few times I put the wax ring on bottom of toilet first. Now for the 4th time I put the wax ring on the flange. I guess I will wait and see. Yes I strictly used wax rings with funnel.
Old 11-27-2013, 04:18 PM   #4
Kcrazyb
When setting any toilets one peace or not always make sure the wax makes contact with the bowl some times you can use the bigger wax like a jumbo Johnny and still have to use an extension the wax without the cone when placing the bowl down on the flange you hold it level has you press the wax. You can feel the wax has you push. If you press the wax at an angle it will deform the wax and possibly make a bad seal the also make flag extensions the bolt on under the bolts
Kcrazyb is offline
Old 11-27-2013, 05:00 PM   #5
newbie666
My flange is a beer bottle caps thickness above the floor, so I used one wax ring. Yes I did feel compression and wiggled it gently down until the toilet touched the floor. Then I sat on it and wiggled around a bit, got some 30lb dumbells and sat on it again. Then hand tightened the nuts, and finished off with a wrench until the oval washers deflected slightly. Reconnect feed line to tank. Flush 3 or 4 times and check for leaks with tissue. That's my install process.
Old 11-27-2013, 05:24 PM   #6
havasu
Administrator
havasu's Avatar
Likes Given: 265
Just a question, did you confirm there were no hairline cracks in either the flange or the porcelain?
havasu is offline
Old 11-27-2013, 05:31 PM   #7
newbie666
I put drops of red food coloring into the tank and bowl for a few days to make sure toilet wasn't cracked. Also inspected the flange and it looks good. Flange is a lead liner inside a cast pipe, which goes down it a good 3-4 inches. Lead flange isn't as smooth as a plastic flange but, the wax should take care of any unevenness I think.
Old 11-27-2013, 05:35 PM   #8
havasu
Administrator
havasu's Avatar
Likes Given: 265
So is the toilet still seeping after the 4th attempt?
havasu is offline
Old 11-27-2013, 06:01 PM   #9
newbie666
Its been 6 hours and 12 flushes, I am hoping and praying as in past installs it has taken a day or 2 to show signs of leaking. The only thing I have done different 4th time around is put the wax on the flange and then put the toilet on top.
I had a theory that maybe the the rough in and or the toilet are so that the black cone isn't exactly on centre with flange so it creates a stress point that put a crack in the wax. Because all the leaks have been on the same side. Is this crazy or plausible.
Old 11-27-2013, 07:35 PM   #10
johnjh2o
johnjh2o's Avatar
Liked 684 Times on 518 Posts
Likes Given: 572
What may have been happening is you were missing the center of the flange when setting the toilet, causing the wax to not come in contact with the flange at some point. By placing the wax on the flange first there is less chance of that happening.
John
johnjh2o is offline
Flange/wax ring Dogstar Toilets and Sinks 2 06-29-2012 11:56 PM
O ring kits, which one and where? phishfood Plumbing Products 3 06-05-2012 11:46 AM
wax less ring issue ishouldacalledaplumber General Plumbing Help 1 04-20-2012 03:24 PM
Installing wax ring havasu Toilets and Sinks 4 10-19-2011 02:50 AM
replacing wax ring on toilet redohiswork2 Toilets and Sinks 5 07-31-2010 12:27 PM
Newest Threads
