Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Draining to the stack
Thread Tools Display Modes
Old 11-14-2013, 04:17 PM   #1
donkall
Default Draining to the stack
I am wanting to put in a second floor bathroom that is about 20 feet from the stack. There are a couple of problems.
First, the waste pipe would run perpendicular to the floor joints and that means a lot of holes- worried about structural integrity of the joints.
Second, even if I got to the stack, the inlet there would be too high in relation to the height of the drains, accounting for the necessary slope of the drain pipe, which would have to drop about five inches from the drain to the stack.
Here's my question:
Can I put a three or four inch drain pipe straight down into the basement, from the bathroom, then slope the pipe over to the stack? It would work logistically but would it be permissible with regard to codes? I could vent out the roof, right at the bathroom, I think. Thanks for your help.
donkall is offline
Old 11-14-2013, 04:40 PM   #2
plumber78
Liked 4 Times on 4 Posts
Likes Given: 6
Absolutely, as long as the bathroom group is vented properly. Do you have a floor plan or rough sketch?
plumber78 is offline
Old 11-21-2013, 01:56 AM   #3
donkall
Thanks for the info. I am just in planning stages but this info helps a lot. Have a good one.
donkall is offline
Vent stack spudDude General Plumbing Help 4 04-30-2013 04:08 AM
No soil stack through the roof?! mxmom General Plumbing Help 11 04-06-2012 03:56 AM
How to test this DWV stack? markcool General Plumbing Help 4 11-23-2011 04:52 AM
Can stack be offset? markcool General Plumbing Help 3 10-22-2011 03:00 PM
FWG Draining into FWG andyb Plumbing Building Code 2 05-31-2010 07:38 PM
Newest Threads
