Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Need to cap a 1 1/4 inch threaded pvc pipe
Thread Tools Display Modes
Old 11-10-2013, 02:39 PM   #1
gmcgarvey
Default Need to cap a 1 1/4 inch threaded pvc pipe
I need to cap a 1 1/4 inch pvc pipe that has male threads. This is part of an indoor residential drain. I see caps on the web that are schedule 40 and schedule 80, but I don't know if either of these will work. Any ideas? Help would be very appreciated.
gmcgarvey is offline
Old 11-10-2013, 02:53 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
SCH 40 or SCH 80 will work. Are you sure it's 1-1/4"? Most are 1-1/2" or 2". 1-1/4" is made but it isn't used very often.
John
johnjh2o is offline
Old 11-10-2013, 03:17 PM   #3
gmcgarvey
It looks like you're right about it being 1-1/2". Thanks so much. Gerry
Leaking threaded pipe joint brimanley General Plumbing Help 0 10-30-2013 02:16 PM
How connect air to 1 inch union irrigation pipe Mikegp12 General Plumbing Help 6 10-24-2013 11:12 PM
How to rejoin an attic PVC vent pipe with a 2 inch gap mtv General Plumbing Help 4 11-04-2011 02:41 AM
Sweat vs Threaded Valve supernewbie General Plumbing Help 5 10-04-2010 11:19 PM
Threaded nylon fillings won't seal ironbob General Plumbing Help 7 06-21-2010 02:58 PM
Newest Threads
