Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Small Bubbles forming in toilet bowls and tanks
Thread Tools Display Modes
Old 10-30-2013, 03:33 PM   #1
armenhamer
Default Small Bubbles forming in toilet bowls and tanks
Less than two weeks ago the city had someone come out to replace our water meter, they're doing this through out the neighborhood. for what it's worth we we're also having a new furnace installed while the meter was swapped out. While checking things out once the meter was changed I noticed our main floor toilet sounded different filling up after flushing. I took apart the fill valve and hooked it back up and that seemed to fix that. However, since that day and I can't be sure if I just haven't noticed it before, there's been tiny air bubbles in the tank and bowl in both the main floor toilet and the one in our basement. When you flush they go away and then reform after a few hours. The longer between flushes the more there seem to be. You can see them attached to the parts inside the tank and around the lip of the hole in the toilet bowl and around the bowl in general where the water is. Can't say that I've noticed any difference in how they flush or fill back up. All the other plumbing from what I can tell runs and drains fine as well. No noises or smells. So I'm not sure if this is normal and I just didn't notice it until now or if something is up?
I will also add you do have to bend down to get a good look at them in the toilet bowl, they are very small.
Thanks in advance for any thoughts on this.
armenhamer is offline
Old 10-31-2013, 12:28 AM   #2
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Sounds like your fill valves are not shutting off completely which is allowing a small amount of water in the tank & bowl causing the bubbles. Your fill valves may have got some debris from the installation of the new water meter. Remove your tank lid and place your ear near the fill valve listening for any sound.
IFIXH20 is offline
Old 10-31-2013, 01:13 PM   #3
armenhamer
Not really hearing anything noise wise and the water level doesn't seem to be changing as far as I can tell. I did close the valve water supply to the tank for a few hours and still got some bubble formation.
This was on the basement toilet, the main floor toilet from what I've seen over the last few days doesn't seem to have much of any bubbles except for around the flap in the tank. Wondering if there's something working itself out through the system? Here's pic of what it looks like in the bowl of the basement toilet.
Old 10-31-2013, 10:06 PM   #4
IFIXH20
HERE TO HELP
Likes Given: 165
Must be air bubbles sticking/forming to a rough area
IFIXH20 is offline
Old 10-31-2013, 11:12 PM   #5
armenhamer
Would you think that's normal? Considering having a pro come out to take a look. Thanks!
Air bubbles, low/high water level, slow draining mauve General Plumbing Help 6 05-16-2013 06:30 PM
small bathroom toilet solution brasstacks Toilets and Sinks 1 07-15-2012 04:00 PM
Toilet making small slurping noise mrmyth Toilets and Sinks 3 02-19-2012 03:58 PM
Air bubbles and trouble flushing track32drummer Toilets and Sinks 2 12-04-2011 12:17 AM
bubbles in basement toilet mcf57 Toilets and Sinks 4 11-29-2010 01:06 AM
