Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Cast Iron Compression drain fitting removal
Thread Tools Display Modes
Old 10-27-2013, 02:34 AM   #1
Liked 1 Times on 1 Posts
Default Cast Iron Compression drain fitting removal
Drain from the kitchen is cast iron going down to the basement. Smelled something and found the wall in the basement was wet.
I want to remove the end cap off to get a camera in the pipe find the leak but having a problem removing the pipe cap without the Ridgid #228 Cast Iron Compression Joint tool.
Any ideas? I tried using a pipe wrench to turn it but it seems to want to be pulled out. Cut the rubber sleeve and dig it out is the only other thing I could think of.
Thanks! JW
JamesWalnut is offline
How to cut out a cast iron fitting in wall. Mr_David General Plumbing Help 9 07-19-2015 01:25 AM
removal of cast iron tub bggas400 General Plumbing Help 13 02-20-2014 01:13 PM
Cast iron shower drain rgrinde Showers and Tubs 8 04-09-2013 05:34 PM
Odd cast iron fitting phishfood Plumbing Products 3 11-19-2012 03:38 PM
cast iron pipe removal slls General Plumbing Help 2 12-14-2011 11:23 PM
Newest Threads
