Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > What kind of valve is this??
Thread Tools Display Modes
Old 10-26-2013, 09:48 PM   #1
gato11311
Likes Given: 1
Default What kind of valve is this??
I am having a problem with leaking outside of my drain pipe from the water heater. I just replaced my TPR valve and noticed that there is still leakage. It must be this other little valve on the cold water inlet. It sounds like water is running through the pipe and there is no leakage except the constant drainage from the outer drain pipe. Question is: Does anyone know what this other valve is and where to buy another to replace it?
gato11311 is offline
Old 10-26-2013, 11:44 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 696 Times on 529 Posts
Likes Given: 581
Can't tell from the picture but it's a vacuum breaker or a pressure relief valve.
John
johnjh2o is offline
Old 10-27-2013, 03:47 PM   #3
gato11311
Likes Given: 1
The Temperature Pressure Relief Valve is not the problem. I just replaced that. It is the other one coming from the cold inlet that connects to the copper tubing right after the TPR. Are you saying it is called a vaccum breaker?
Old 10-27-2013, 03:53 PM   #4
johnjh2o
johnjh2o's Avatar
Likes Given: 581
Quote:
That's the one I was referring to in my first reply. Can't see enough of it to determine which it is.
John
johnjh2o is offline
Old 10-27-2013, 04:52 PM   #5
gato11311
Likes Given: 1
I think it is another pressure relief valve after comparing others on the web. Thanks for pointing me in the right direction. Just wierd that I have two (the t&p and this one).
Old 10-31-2013, 07:13 AM   #6
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
Likes Given: 1
It's a mixing valve( I think)
Never seen one like that maybe the knob is broken off of that but only way is to cut it out and replace it... No replacement parts
camaroderrick73 is offline
Old 10-31-2013, 12:05 PM   #7
johnjh2o
johnjh2o's Avatar
Likes Given: 581
I don't think it's a mixing valve because it connected to the discharge of the T&P valve.
John
johnjh2o is offline
Old 11-02-2013, 02:35 AM   #8
klee181438
Liked 1 Times on 1 Posts
This is a thermal expansion valve. They are more trouble then they're worth. Id remove it and cap the line, then install an expansion tank on the cold water side. Problem solved
Atlanta, GA Plumber
Metro Septic and Plumbing
678-873-7934
http://www.metrosepticandplumbing.com
klee181438 is offline
Old 11-02-2013, 02:40 AM   #9
klee181438
This picture shows the valve, usually made by Watts
Atlanta, GA Plumber
678-873-7934
What kind of drain is this? dacattyo Drain and Sewer Cleaning 1 06-06-2013 10:03 PM
What kind of valve do I have to buy for under the kitchen sink? amateurplumber General Plumbing Help 4 03-21-2013 01:51 AM
What kind of lubricant for mixing valve? Rohey General Plumbing Help 9 04-28-2012 10:21 PM
can anyone tell me what kind of fixture this is? killbreth General Plumbing Help 3 11-13-2011 07:52 PM
What kind of spigot insert is this? mikeu1 General Plumbing Help 2 06-07-2010 12:40 AM
Newest Threads
