Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Help with Harcraft tub valve
Thread Tools Display Modes
Old 10-24-2013, 02:23 AM   #1
DKO
Default Help with Harcraft tub valve
I have a Harcraft tub faucet with separate hot/cold water handles. The escutcheon type flange won't go on - it gets stuck after a few turns. Tried cleaning the threads but no go. I tried the one that screws on the opposite handle valve, but it won't screw on and gets stuck at same point. Any suggestions other than removing tile and replacing the valve itself? I will try to attach a picture.
DKO is offline
Old 10-26-2013, 01:38 PM   #2
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
If none of the escutcheons screws on that stem, replace the stem don't replace the valve.
IFIXH20 is offline
Failing Check valve or foot valve on irrigation well? timfitz Pumps and Wells 3 07-13-2012 12:04 PM
Pressure Balance Valve and Volume valve in Series TimHomeowner55 General Plumbing Help 4 09-03-2011 03:35 PM
Harcraft faucet djhowe46 General Plumbing Help 2 04-26-2011 10:38 PM
