Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > How connect air to 1 inch union irrigation pipe
Thread Tools Display Modes
Old 10-22-2013, 02:38 PM   #1
Mikegp12
Likes Given: 2
Default How connect air to 1 inch union irrigation pipe
I have removed my backflow device for the winter and am installing unions for easy removal. Now I need to know how I can connect air compressor to the union (male end) for blow out. It is a 1 inch union.
I am trying to find a way to not blow through the backflow because I have had to replace the seals and gaskets twice in 4 years and suspect the air caused this.
Mikegp12 is offline
Old 10-23-2013, 04:29 AM   #2
chukar
Liked 20 Times on 18 Posts
If your piping is PVC for the irrigation, I installed a tee after my RPBA that has a shut off valve with a male threaded plug in it most of the year, i simple take the plug out put in a brass 1" x 3/8" bushing then I can connect directly to my air hose for my compressor. Allows me easy hook up, also if I want in the future gives me a place to add chemicals for say my lawn.
chukar is offline
Old 10-23-2013, 02:28 PM   #3
Mikegp12
Likes Given: 2
Thanks Chukar, but this is going on copper pipe.
Mikegp12 is offline
Old 10-24-2013, 04:30 AM   #4
chukar
Now that you posted a pic in the other thread it's even easier put the union where it leaves the wall, unthread the assembly, take it out and screw on a 1" coupling then use your bushing to attach your air system.
chukar is offline
Old 10-24-2013, 08:15 AM   #5
johnjh2o
johnjh2o's Avatar
Liked 717 Times on 544 Posts
Likes Given: 610
Quote:
That is not a 1" pipe thread. It' where the nut that connects the two union halfs together. The size varies depending on manufacture. But in any case it isn't a standard pipe thread.
John
johnjh2o is offline
Old 10-24-2013, 03:43 PM   #6
Mikegp12
Likes Given: 2
After all the time I have put into searching for the right fittings maybe I should just do this. I was hoping to avoid any extra soldering but winter is fast approaching.
Mikegp12 is offline
Old 10-24-2013, 11:12 PM   #7
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Quote:
You can do that, but you would have to leave the backflow in place (or find another way to block the union you just installed) and shut the valve off to the backflow in order to blow your sprinkler system out. Just install that set-up on the piping on the backside of the backflow and shut the backflow backside valve off to blow out system and prevent air from flowing through backflow. Hope that makes sense.
IFIXH20 is offline
Mikegp12 Likes This
1 inch copper union Mikegp12 General Plumbing Help 6 10-24-2013 01:39 PM
gas pipe union jocar General Plumbing Help 2 07-03-2013 10:44 PM
Pipe vibration when irrigation on rrauenza General Plumbing Help 5 04-16-2013 06:06 PM
what is the order to connect the pipe q0987 General Plumbing Help 18 03-27-2013 03:22 AM
How to rejoin an attic PVC vent pipe with a 2 inch gap mtv General Plumbing Help 4 11-04-2011 02:41 AM
Newest Threads
