Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Old three handle Kohler shower/tub faucet
Thread Tools Display Modes
Old 10-20-2013, 11:40 PM   #1
ScottStaral
Liked 3 Times on 3 Posts
Default Old three handle Kohler shower/tub faucet
Hello,
I just had the old cast iron tub refinished as a temporary fix before I can do a complete remodel of the bathroom. The place that did the refinishing was the local Surface Specialists. they noted that the tub faucet was dripping a little bit and recommend to get it repaired as soon as possible.
Before I go taking anything apart, can any one identify this old Kohler three handle tub/shower faucet, and if parts are still available?
see attached images.
Thanks
Scott
ScottStaral is offline
Zanne Likes This
Old 10-22-2013, 01:59 AM   #2
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Remove the diverter stem and post a pic. You can remove the diverter stem with out turning off the water to the house.
IFIXH20 is offline
Old 10-24-2013, 12:08 AM   #3
ScottStaral
I'll have to go get some stem wrenches.
I'm not even sure anything is even leaking. The tub/shower hasn't been used for two days now and there is no water dripping from the faucet as the area under the faucet around the drain is completely dry.
I think what he saw dripping was the residual water in the pipes after the faucet is turned off.
I will take apart anyways as this is in an apartment I just bought and if a situation arises after a tenant is in there, at least I'll know what parts I will need.
Zanne Likes This
Old 11-17-2013, 10:23 PM   #4
janetbrauns
Liked 1 Times on 1 Posts
Likes Given: 9
Quote:
Originally Posted by ScottStaral View Post
Hello,
Thanks
Scott
That looks exactly like the Briggs handles and faucet valve body that I have. I replaced the handles, stems and seats with a Danco rebuild set.
janetbrauns is offline
Old 11-17-2013, 11:23 PM   #5
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
Those old 3 handle valves look very similar from the backside of the wall.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 03-04-2014, 03:07 AM   #6
ScottStaral
Quote:
a little delayed, but here is a pic of the cold side, stem. I couldn't budge the diverter, the cold came right out.
Zanne Likes This
Old 03-07-2014, 03:59 PM   #7
SHR
Liked 282 Times on 214 Posts
Likes Given: 789
I am sure you can purchase replacement stems and seats for that fixture. Although when working on other peoples faucets we usually replace the whole stem to be sure everything works good, you can replace the bibb washers on the ends of the stems. The seats in the faucet body that the washers compress against can and should be resurfaced or replaced when changing bibb washers. It looks like that stem was recently repaired with a beveled washer. In the US beveled washers are rarely used by original manufacturers but they work ok. If the hot side stem looks to be in similar good shape you can just continue to repair the stems and seats to save a lot of money. If you choose to repair use flat washers.
SHR is offline
Old 04-01-2014, 10:33 PM   #8
Carl399
Liked 2 Times on 1 Posts
Likes Given: 3
Hi,
Not familiar with that particular faucet, but work with old fixtures. You might want to check out HD Supply. They stock parts for my 60+ yr old A/S fixtures
Carl399 is offline
A leaky faucet - and i can't remove the faucet handle Mkperez General Plumbing Help 3 08-05-2013 03:02 AM
Delta shower single handle faucet help scrabbler Showers and Tubs 1 08-14-2012 03:42 PM
Old Shower faucet handle ID Cambello General Plumbing Help 15 09-08-2011 10:57 PM
Moen single handle shower faucet rough in Dogstar General Plumbing Help 3 03-05-2011 01:10 AM
Replace Moen shower handle with Kohler mrchad Showers and Tubs 4 06-05-2010 04:28 PM
Newest Threads
