Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Building Code > Trap outlet same level as disposal outlet
Thread Tools Display Modes
Old 10-19-2013, 07:13 PM   #1
dave80906
Default Trap outlet same level as disposal outlet
Is it against code or otherwise ill-advised to have the discharge end of the p-trap at the same level as the discharge port of the disposal? Seems like that might result in water standing in the disposal.
dave80906 is offline
Old 10-19-2013, 08:49 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 704 Times on 536 Posts
Likes Given: 590
Is it at the same height as the disposal outlet or the bottom of the outlet ell on the disposal? It can be piped without using the outlet ell. A picture would help.
John
johnjh2o is online now
Old 10-20-2013, 05:00 PM   #3
dave80906
It is close to the same level as the outlet itself, maybe 1/4" lower.
Old 10-20-2013, 06:59 PM   #4
johnjh2o
johnjh2o's Avatar
Likes Given: 590
It looks like if you shorten up the disposal ell, you could use a standard tubular trap without the extension between the two sections of the trap.
John
Old 10-21-2013, 01:01 AM   #5
dave80906
It does look that way, but the extension that slips over the ell won't go up high enough to allow that. My bigger concern was just whether the tap into the vertical drain pipe in the wall being virtually as high as the disposal outlet would create a problem.
Old 10-24-2013, 12:51 AM   #6
phishfood
Administrator
Liked 943 Times on 759 Posts
Likes Given: 1684
As long as the disposal outlet is even the slightest bit higher than the trap arm, the disposal will drain completely. Which is what you want to happen, you don't want the disposal to retain water.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 10-30-2013, 03:46 AM   #7
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
Likes Given: 1
Code says 2 to 4 in only at the weir of the trap.. Technically .. That is ok
camaroderrick73 is offline
Old 10-30-2013, 03:48 AM   #8
camaroderrick73
Likes Given: 1
This is prime example that people need to explore all options before putting in a deep basin sink. Also... No air gap?
Old 03-06-2014, 01:56 AM   #9
SHR
Liked 260 Times on 196 Posts
Likes Given: 710
Quote:
I am not a fan of air gaps, often they fail and leak causing water damage. Fortunately, inspectors in my area do not require them. BUT raise the dishwasher drain line up the the bottom of the countertop and secure it there. Otherwise you will often find ground up food particles in the bottom of your dishwasher...ick!
I would be very concerned about the flexible tube used to raise and connect the trap to the wall tube. Now that is a code violation in my area. NEVER ever use flexible corrugated tubular drainage parts. They are disasters waiting to happen and just not the right way to plumb a sink drain. Eliminate that part!
Edit: I now realize dave80906 did probably use a regular extension tube. Oops, sorry.
SHR is offline
Old 03-06-2014, 02:04 AM   #10
phishfood
Administrator
Likes Given: 1684
I took that to be a standard slip joint extension tube. It could be a flexible connector, hard for me to tell from the picture.
New Sink Garbage Disposal P Trap Issue RichG General Plumbing Help 10 03-16-2013 03:32 PM
How do seal the bottom of the sink/plastic overflow outlet on an enameled steel lava stouto General Plumbing Help 4 12-25-2011 12:28 AM
Rear Outlet Toilet Question - Rough in - HELP! tungsten79 Toilets and Sinks 1 07-22-2011 04:11 PM
Reinstalling Disposal dwh1262 Toilets and Sinks 4 06-08-2011 08:22 AM
Toilet Bowl Water Level Alternates Level and Flush leichte Toilets and Sinks 2 09-15-2010 02:00 PM
Newest Threads
