Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Leaking drain pipe connection
Thread Tools Display Modes
Old 10-13-2013, 05:50 PM   #1
Default Leaking drain pipe connection
I just drained about a gallon of water out of my pantry ceiling and need advice on how to fix a leaking 2 inch copper drain connection. I believe the leak is facing away from my access point. I can only assume that the pipes are soldered together, but I can't actually see.
bcoop82 is offline
Old 10-13-2013, 07:13 PM   #2
johnjh2o's Avatar
Liked 731 Times on 555 Posts
Likes Given: 625
Copper waste line joints don't usually fail over time. But copper drain lines do. Many copper drains were DWV tubing which was a light weight copper pipe. The first signs of failure is green spots along the top or bottom of the pipe. At these points you can crush the pipe with your fingers. In time they will become holes. The only repair is to replace the pipe.
johnjh2o is offline
IFIXH20 Likes This
Old 10-13-2013, 07:15 PM   #3
Liked 236 Times on 187 Posts
Likes Given: 165
Open the ceiling to expose the drain. Take and post pics of needed repair.
IFIXH20 is offline
Old 10-13-2013, 11:20 PM   #4
Thx guys, I replaced the pipes.
bcoop82 is offline
Help! connection to kitchen faucet hose/pipe leaking pineapple808 Toilets and Sinks 4 08-18-2012 11:15 PM
Friend has weird connection to drain line w/ pump? ardcarmvk Water Heaters and Softeners 1 06-05-2012 04:23 AM
pipe connection Mec Drain and Sewer Cleaning 4 03-27-2012 12:49 AM
2washing mashines, 1 connection and drain Laundryqueen General Plumbing Help 4 03-13-2012 12:33 PM
Faucet Connection Tube/Pipe mcburton Toilets and Sinks 2 02-15-2011 05:03 PM
Newest Threads
