Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Central Heating pump not working, help please?
Thread Tools Display Modes
Old 10-12-2013, 12:49 PM   #1
JayBlake
Default Central Heating pump not working, help please?
Hi everyone,
First time poster (please be gentle).
Generally handy chap in need of a little more expertise, if possible.
A few nights ago, my radiators went cold
Having tried all the resets and radiator bleeding etc., I noticed that whilst the boiler was kicking in and the hot water tank was filling, the background pump noise was missing, so I located the pump (Picture 1, attached - note the compromised power chord to the lower left). I didn't notice the power lead, at first and simply increased the setting from 2 to 3, without any luck (I also gave the pump a couple of measured wallops in case there was some debris inside, stopping the pump). No joy.
I then noticed the power cable is all split and the live wire's core is actually exposed (pics 2 and 3 attached).
Is it likely (or possible) that simply rewiring the pump may effect a repair?
Are there any pitfalls I may encounter (incidentally, the current plug is of the very old-fashioned small (half-size?) round pin variety which I suspect may be not even earthed.......should I also replace that?).
What may have caused this as I believe the pump is only around four years old?
The back of my upright freezer hides the in-kitchen-wall plumbing and is probably around 3 to 4 inches away from the pump and the cable. Should I place a barrier between, do you think?
I know it may appear that I'm trying to answer my own questions, but am not attempting to state-the-bleedin'-obvious, rather I am nervous of cocking it all up, through my ignorance.
Many thanks for reading.
Please feel free to ask questions.
Jib T
PA120314_heating-pump-001.jpg   PA120316_heating-pump-002x800.jpg   PA120318_heating-pump-003x800.jpg
JayBlake is offline
Old 10-12-2013, 01:10 PM   #2
JayBlake
PS. Do I need any specialist electrical cable or can I use heavy-duty, three-core, white sleeved cable, of which I have a drum of.
Thanks.
JayBlake is offline
How well is my softener working? jessb_55 Water Heaters and Softeners 11 07-04-2012 02:28 PM
One Side of Faucet Not Working mrsmnc Toilets and Sinks 1 10-23-2011 11:13 PM
New radiator not working, please help Yardley Water Heaters and Softeners 18 10-12-2011 12:40 AM
Central Brass makes CRAPPY CERAMIC STEMS NickfromPittsburgh Plumbing Products 0 05-26-2011 05:04 PM
Outside hose bib not working Brian87gt General Plumbing Help 2 02-28-2011 12:50 PM
Newest Threads
