Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Can you install dual check valves underground for irrigation system?
Thread Tools Display Modes
Old 10-10-2013, 04:23 AM   #1
Fusion916
Default Can you install dual check valves underground for irrigation system?
I'm going to redo my irrigation system and instead of using the above ground anti-spihon valves I want to install a dual check valves and then inline timer valves.
The DC valve im thinking of getting is this one:
http://www.amazon.com/Wilkins-Reduce...le+check+valve
I want to install both the DC valve and inline valves underground. Is that allowed in CA? I know anti-siphon valves have to be (I think) 12 inches above the highest sprinkler, but don't know if that also applies to the pro grade DC valves.
Fusion916 is offline
Old 10-10-2013, 12:13 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 717 Times on 544 Posts
Likes Given: 610
First off that's not a dual check. It's an RPZ device. (reduced pressure zone) That device can not be installed under ground. A dual check is not and approved device because it can't be tested. You may be thinking of a DBL check. That device has test cocks a dual check doesn't. Both the RPZ and the DBL check are much more expensive then the PVB
(pressure vacuum breaker). What is your reason to not use the approved device for your irrigation system. (PVB)
John
johnjh2o is offline
Old 10-10-2013, 03:11 PM   #3
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
We install that very device here in Southern CA in many commercial irrigation lines but I have never installed one under ground, they have always been brought above ground with an air gap under then back down under ground. I am also curious of why you are not going with the norm?
Chris is offline
Old 10-10-2013, 06:20 PM   #4
Fusion916
Is a RPZ and double check the same except the pressure reduction? It looks the same:
http://www.amazon.com/Wilkins-Double...le+check+valve
I'm 100% sure the double check and RPZ devices are approved where I live because I literally see them everywhere on commercial properties. I have never seen that PVB devices anywhere in CA so I don't think that's legal here.
The reason I'm looking to get a separate check valve is so I don't have to use those above ground anti-siphon valves, but instead use a bunch of buried inline valves. Even if I have to elevate the double check, it would only be one thing elevated while I can bury the many inline valves I need.
Old 10-10-2013, 08:32 PM   #5
johnjh2o
johnjh2o's Avatar
Likes Given: 610
This is a PVB. I'm sure you will find it is an approved device for your system.
http://www.amazon.com/s?ie=UTF8&page...cuum%20breaker
John
johnjh2o is offline
Old 10-10-2013, 08:45 PM   #6
Fusion916
Given it is, does this also need to be elevated above ground? and if so, by how much?
Old 10-12-2013, 04:58 AM   #7
chukar
Liked 20 Times on 18 Posts
I believe it has to be at least 12" about your highest outlets or feed. So if your property is flat it's like 18" off the ground to the center line radius, but if you have a sprinkler head that is going to be taller then that on say a sloping years you have to raise it up. A PVB protects against back siphonage only, not back pressure. A double check valve will protect against back pressure and can be installed in a pit, assuming you have proper clearances.
chukar is offline
Old 10-13-2013, 07:13 AM   #8
Fusion916
What is the difference between back siphonage and back pressure?
Old 10-13-2013, 03:06 PM   #9
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
Back pressure is when additional pressure is created within the water system after the service, such as thermal expansion, and puts pressure on the incoming service. Back siphonage is when a negative pressure is created before the service causing the water to be drawn back towards the water service.
Positive for one, negative pressure for the other.
Caduceus is offline
Old 10-14-2013, 04:01 AM   #10
Fusion916
Why (for residential use) do you need to protect from anti-siphon but not back pressure? Do check valves protect from both? Most residential sprinkler valves are anti-siphon valves but say nothing about protecting from back pressure. Do the industrial check valves (the big double check valves) protect from both?
Dual Check Valves high pitch sound nganchris General Plumbing Help 1 05-16-2013 02:34 AM
Install Looped Mainline for Drip Irrigation 1000' dishheadd General Plumbing Help 11 04-14-2012 02:35 AM
Check valves in showerhead LesF Showers and Tubs 3 03-14-2012 03:05 AM
Submersible Check Valves Pikanjoe Pumps and Wells 3 12-03-2011 02:39 PM
Mosquito problem. Has anyone plumbed malathion into their irrigation system? RakeThrower General Plumbing Help 1 09-27-2011 02:32 PM
Newest Threads
