Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Wax leaking at toilet base?
Thread Tools Display Modes
Old 10-03-2013, 04:48 AM   #1
mmurphy
Default Wax leaking at toilet base?
Howdy,
I recently installed a toilet and it's been working great, but today I discovered what appeared to be wax, same color and textrue as the wax ring, oozing out through part of the base. Obviously, I missed a spot when I caulked, but I want to make sure there are not likely any underlying problems. There was not, as far as I could tell, any water leakage. The ring is an extra thick, reinforced model from Flushmaster. I figure if it's just wax that got squished (there being so much of it), then just some additional caulking might do the trick. If it's something else, though, I don't want water to be leaking under the base and compromising my subfloor. Any ideas? I'd prefer not to have to remove the toilet and do this all over again, especially if it turns out nothing was wrong.
Thanks!
mmurphy is offline
Old 10-05-2013, 03:21 PM   #2
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
As long as there are no leaks, there probably aren't any other problems. I prefer not to caulk the base of toilets unless it's a commercial job so that any future leaks can be spotted easier and early before serious damage has been done to the floor.
Caduceus is offline
Old 10-06-2013, 12:05 PM   #3
robmcg
Liked 1 Times on 1 Posts
Quote:
One of the first things I was taught
robmcg is offline
Old 10-06-2013, 12:07 PM   #4
robmcg
Quote:
When I entered the trade was never put a socket to a fixture and never caulk a toilet that's not sitting on concrete. I agree with cadaceus. Just keep ur eye on it and try to. Get rid of caulking if possible
robmcg is offline
Old 10-06-2013, 01:03 PM   #5
phishfood
Administrator
Liked 964 Times on 775 Posts
Likes Given: 1739
Florida Building Code, Plumbing 405.5 Water tight joints
Joints formed where fixtures come in contact with walls or floors shall be sealed.
That has been part of the code ever since I can remember. The reason I was given that code requires this is so that water from cleaning operations does not get underneath the fixture and create a breeding ground for bacteria. I have had inspectors fail final inspections because one of my guys missed a spot when they were grouting a toilet to the floor, and have even had an inspector make me caulk a freestanding laundry tub to the wall because of this code section.
I understand why you would not want to seal a toilet to the floor with a wood subfloor underneath, but shimming a toilet correctly, testing it well, and then grouting or caulking the toilet to hold the shims in place hasn't let me down yet. I will admit that when I set a toilet over a wood framed floor, I usually try to cheat and leave a little space at the back of the toilet open.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
People Like This
Old 10-06-2013, 01:24 PM   #6
Caduceus
Caduceus's Avatar
Likes Given: 230
Yeah, I exercise a little flexibility with my residential installations to accommodate the situation, especially with homes 50+ years old. When you notice the old water damage from previous leaks and don't know what caused them (really big people tend to sit down really hard and shift toilets, perhaps?) having a tattle-tale could help the owner catch a problem before it gets critical. But note, all commercial jobs urinals, toilets, sinks, etc. are caulked for the same reason stated above. That also applies to commercial kitchen sinks in restaurants.
Caduceus is offline
The building assume my toilet leaking... cooper General Plumbing Help 16 05-03-2012 06:12 PM
leaking wax ring on my toilet cybermut2000 Toilets and Sinks 6 04-29-2012 01:03 AM
Please help, shower leaking under toilet have tried everything! kinnz03 Showers and Tubs 2 06-14-2011 12:09 AM
toilet leaking? michaelooch Toilets and Sinks 1 10-14-2010 12:28 AM
toilet leaking into overflow pipe bridgeboy Toilets and Sinks 17 02-27-2010 07:06 AM
Newest Threads
