Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > kohler toilet repair
Thread Tools Display Modes
Old 09-26-2013, 08:44 PM   #1
laura78
Default kohler toilet repair
I have an older model Kohler angle toilet. I purchased a fluidmaster universal toilet repair kit and replaced all of the parts inside the tank. now the toilet just doesn't flush right. It flushes but the tank doesn't fill back up until you hit flush handle a second time. Problem with how it was installed or is the kit just not compatible with my toilet?
laura78 is offline
Old 09-26-2013, 09:15 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 704 Times on 536 Posts
Likes Given: 590
We need a picture or the model of the toilet you have.
John
johnjh2o is offline
Old 09-26-2013, 10:33 PM   #3
laura78
Kohler K4519
laura78 is offline
Old 09-26-2013, 11:31 PM   #4
johnjh2o
johnjh2o's Avatar
Likes Given: 590
Fluid master fill valve will work. The flush valve should also work. Did you read the instructions and adjust the fill valve to the correct height?
John
johnjh2o is offline
Old 09-26-2013, 11:33 PM   #5
havasu
Administrator
havasu's Avatar
Liked 1070 Times on 866 Posts
Likes Given: 299
It's possible your Fluidmaster kit is defective. A picture of the insides of your toilet tank would help us help you better.
havasu is offline
Old 09-27-2013, 07:49 PM   #6
laura78
Default picture
picture attached
laura78 is offline
Old 09-27-2013, 08:36 PM   #7
havasu
Administrator
havasu's Avatar
Likes Given: 299
Based on the stained water line in your tank, you need to remove the Fluidmaster valve and unscrew it to raise the height. It appears to be a few inches too low, causing you to have less than the needed water in your tank to operate correctly.
havasu is offline
phishfood Likes This
Old 09-28-2013, 02:46 AM   #8
laura78
Thank you so much for the advice I will give it a try!
laura78 is offline
Old 09-28-2013, 04:33 AM   #9
havasu
Administrator
havasu's Avatar
Likes Given: 299
You do have some adjustment on the black valve, which might help you a bit. Seeing only a downshot pic of the tank, it is hard to tell how much adjustment is really needed. There is an "X" which holds a Phillips screwdriver perfectly and by twisting it, you might gain an inch or so without removing and expanding the valve. I'm just throwing this out in case you are reluctant in removing and expanding the Fluidmaster valve.
havasu is offline
Old 09-28-2013, 06:29 AM   #10
johnjh2o
johnjh2o's Avatar
Likes Given: 590
The fill valve you have is the fluid master 400LSR. That thing is a bear to adjust. There is a second chain that prevents the toilet from filling if the flapper should hang up. If not adjusted correctly you will have the problem that you are describing. You can try reading the instructions and get the correct adjustments, but my advice would be to remove it and install the standard fluid master 400. The flapper and flush valve can stay.
John
johnjh2o is offline
Kohler Cimmaron cruser Toilets and Sinks 1 09-25-2013 01:59 PM
Kohler toilet problems bgreen Toilets and Sinks 8 10-09-2011 08:36 PM
Running Kohler Toilet orfeo Toilets and Sinks 4 05-08-2011 07:27 AM
1915 Toilet Repair gman Toilets and Sinks 2 02-21-2011 07:14 PM
Toilet Repair Lisa Toilets and Sinks 4 12-08-2010 02:54 AM
Newest Threads
