Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > goulds HSC20 underwater. Is it damaged?
Thread Tools Display Modes
Old 09-15-2013, 02:10 PM   #1
chaseme5
Default goulds HSC20 underwater. Is it damaged?
Last night our 5000 gal tank overflowed. It flooded an area that housed an goulds HSC20 3 ph booster pump. The pump was under 5 ft of water for some time. At least a couple of hours. There are no fuses blown. The model of HSC20 we have is the totally enclosed version I think.
What will have to be replaced on the pump? If it runs will the motor bearings need replacement.
We have a Danfoss VFD and I think it cut power to the pump because no blown fuses were found. The drive was in fault mode. I turned off power to the system.
chaseme5 is offline
Old 09-15-2013, 03:20 PM   #2
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 198 Times on 181 Posts
Likes Given: 46
If it's TEFC, and real tight water shouldn't have gotten in. But if it did, the bearings won't last long at all. If it's ODP, you will have to change then very soon. Electrically, it shouldn't hurt it at all other than corrosion on start points and capacitor connectors. I think you said it was 3 phase, if so there is no points or capacitor.
speedbump is offline
Old 09-15-2013, 10:12 PM   #3
chaseme5
How will I know the bearings will need replacement? Will the motor make any noises?
chaseme5 is offline
Old 09-16-2013, 12:56 PM   #4
speedbump
speedbump's Avatar
Likes Given: 46
Oh yeah, it will be screaming if the grease got washed out of them.
Old 01-02-2014, 12:36 AM   #5
chiraldude
Hardcore DYI-er
I bought a house with a jet pump in the basement. It had been under water for a couple of months. It ran for quite some time actually but I had to replace it because it made so much noise it was unbearable.
Bottom line is that, if the bearings start to fail, you will hear it. It will probably fail slowly, getting louder and louder before it finally seizes.
chiraldude is offline
Street Workers Damaged our Water Line litleclay General Plumbing Help 11 06-26-2012 04:48 AM
goulds pump problem or well problem? gg05 Pumps and Wells 3 05-04-2012 12:36 PM
Can a freeze-damaged Gould water pump be rebuilt? Stevious Pumps and Wells 6 07-12-2011 12:41 PM
Renters damaged old (1975?) shower fixture brian79z General Plumbing Help 12 03-15-2011 04:03 PM
Newest Threads
