Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Debris in well- ? remove
Thread Tools Display Modes
Old 09-10-2013, 11:51 AM   #1
labtek
Default Debris in well- ? remove
Hello to the group and good day.
I bought a piece of property with an existing drilled well (140 feet) but has not been used for approximately 20 years. It has a submersible pump. While trying to remove the pump, we discovered that over the years mice had gained access to the casing (6 inch) and had been nesting in the upper part of the casing and there was stored seed material in the well above the pump level.
This made removing the pump very difficult. Over the years, the seed material had grown into a mat of unknown thickness.
The pump was not returned to the well because we expected that the screens would be clogged immediately. We also feared losing the pump.
Has anyone ever encountered this problem before or any suggestions as to how to remove the debris. My hope was to be able to use the water to just flush the toilet in my RV. It was not my intention to use the water from this well for drinking.
labtek is offline
Old 09-10-2013, 02:10 PM   #2
Valveman
Pump Controls Tech
Valveman's Avatar
Liked 77 Times on 65 Posts
Likes Given: 1
You need a suction bailer on a sandline to remove that kind of stuff from a well. I have bailed all kinds of stuff out of wells. One time I bailed out about 20’ of rabbits that had fallen down an open well. Lot of eyeballs and fur, it was really disgusting.
www.cyclestopvalves.com
Valveman is offline
Old 09-10-2013, 03:36 PM   #3
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 211 Times on 192 Posts
Likes Given: 46
Same here, only mine were Rats. I would plug that hole and forget it.
speedbump is offline
Old 09-10-2013, 08:40 PM   #4
Valveman
Pump Controls Tech
Valveman's Avatar
Likes Given: 1
I think cleaning it out and getting it pumping helped. Plugging the well would just let the soup migrate south with the aquifer. But it probably had already been doing that anyway.
Valveman is offline
Old 09-10-2013, 08:42 PM   #5
labtek
@Speedbump- thanks for the post however, I do not want to abandon the well before all reasonable options are explored given the cost of a new one. Both you gentlemen seem to suggest using a suction bailer on a sandline. Would a well drilling company have such a device?
labtek is offline
Old 09-11-2013, 12:33 AM   #6
speedbump
speedbump's Avatar
Likes Given: 46
Some will, the rotary guys probably won't. Look for an old timer cable tool driller. He knows what to do.
Old 09-11-2013, 01:30 PM   #7
Valveman
Pump Controls Tech
Valveman's Avatar
Likes Given: 1
A lot of pump companies have suction bailers even though they don't do any drilling.
Valveman is offline
Old 09-12-2013, 11:21 AM   #8
labtek
What are your thoughts about sending high pressure water into the well below the level of the debris? Would that force the debris to the surface and out the top of the casing? There is an abandoned dug surface well near the drilled one as a water source. Thanks.
labtek is offline
Old 09-12-2013, 12:46 PM   #9
speedbump
speedbump's Avatar
Likes Given: 46
High pressure is not what you need, it's high volume that might help.
Old 09-12-2013, 02:05 PM   #10
Valveman
Pump Controls Tech
Valveman's Avatar
Likes Given: 1
You could blow it out with enough air, but not with water.
Valveman is offline
HELP - How do I remove this drain flange? Krupke Toilets and Sinks 7 05-05-2013 01:27 PM
How to remove this faucet stem (PIC) draghi General Plumbing Help 5 08-05-2012 02:27 AM
Best way to remove iron? Brandon General Plumbing Help 1 04-06-2012 02:31 PM
How to remove the cover? danielsd Drain and Sewer Cleaning 3 09-24-2011 11:19 AM
Water softener sending debris through pipes? ds5 Water Heaters and Softeners 5 09-08-2010 12:09 AM
Newest Threads
