Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Help w/ New Drain Lines in Bathroom Remodel
Thread Tools Display Modes
Old 08-30-2013, 04:27 PM   #1
michaelsuder
Default Help w/ New Drain Lines in Bathroom Remodel
I am planning a remodel and will be replacing an existing sink with a double sink vanity and also adding a new bathtub (existing shower to be removed). I do not want to cut the slab for any new drains. My question is, can I tie in the additional sink and the new bathtub drains into the existing sink drain (1-1/4") by routing them in the wall? The new bathtub drain is 8' from the existing sink drain and can sit higher to accommodate a P trap as it is a drop in model and will be set into a custom height platform. The inlet pipe for the existing sink drain enters the wall at 17-3/4" above the slab.
michaelsuder is offline
Old 08-30-2013, 04:50 PM   #2
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
Likes Given: 1
The short answer is no. The shower is usually in the middle of the floor an the tub is in the left or right . Also the pipe size if different. 2in for shower and 1.5 for tub.
As for the lavatory, you can "dirty arm " up to 5 feet. I suggest you look into your local codes to see if this is available via code in your area.
camaroderrick73 is offline
phishfood Likes This
Old 08-30-2013, 04:52 PM   #3
camaroderrick73
Likes Given: 1
You cannot run all three fixtures on that pipe . The
Bathroom/Laundry remodel: Assistance requested Zanne General Plumbing Help 59 11-17-2014 12:10 PM
Bathroom remodel bogro7391 Showers and Tubs 2 04-09-2013 02:31 AM
Moving Drain in Slab & Copper Lines In The Way Higgy General Plumbing Help 4 05-07-2011 05:04 AM
faucets for a bathroom remodel dirtracer74 General Plumbing Help 3 12-26-2010 11:12 PM
Getting drain lines through Joists b-ry39 General Plumbing Help 2 11-18-2010 02:47 PM
Newest Threads
