Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Hot Water Tank Noise
Thread Tools Display Modes
Old 08-19-2013, 03:03 PM   #1
karnold
Default Hot Water Tank Noise
I am having issues trying to find the source of a noise that is coming from a water heater which was installed by a company in Ottawa.
The noise appears only what the water heater turns on but normally disappears shortly after. I seems to be able to recreate the noise gently pushing on the tank or the pipes. The tank is level and all the connection seems to be tight. The only thing I could think of is maybe the anode may be lose.
Anyone have any ideas or have encounter this issue before?
I got a friend to posted a video I to give you guys a better listen:
Thanks,
John
karnold is offline
Old 08-19-2013, 04:13 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 692 Times on 526 Posts
Likes Given: 579
That sounds like metal on metal. It may be the baffle in the heater that is loose and banging around when the burner fires.
John
johnjh2o is offline
LiQuId Likes This
Old 08-19-2013, 11:12 PM   #3
Caduceus
Caduceus's Avatar
Liked 348 Times on 254 Posts
Likes Given: 230
I think John hit the nail on the head.
Caduceus is offline
Old 08-21-2013, 01:23 AM   #4
karnold
Thanks for the response. Is this an easy or even a possible fix? The new tank was installed in February 2013 by a crappy license plumber.
Thanks,
Kris
karnold is offline
Old 08-29-2013, 01:01 AM   #5
AQualityPlumber
Plumber
AQualityPlumber's Avatar
Liked 13 Times on 11 Posts
I would call the manufacturer. Chances are if it's that new it may be under warranty. Call them first because they may send their own preferred vendor to fix it.
A Quality Plumber Inc.
www.PlumbingWA.com
www.plumbingwa.blogspot.com
AQualityPlumber is offline
Water in bottom of heater tank - and - hot water in cold lines SteveRiley Water Heaters and Softeners 14 11-09-2012 01:17 AM
Water Thumping Noise russincincy General Plumbing Help 6 07-30-2012 12:34 PM
Water heater noise DFBonnett Water Heaters and Softeners 4 07-04-2011 08:07 PM
Vibration and noise from water pump inlet wunof11 Pumps and Wells 5 05-16-2011 09:19 PM
Water Heater Piping Noise Corganer Water Heaters and Softeners 5 03-12-2010 02:35 PM
Newest Threads
