Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > new well casing depth
Thread Tools Display Modes
Old 08-11-2013, 02:58 PM   #1
Established Member
Default new well casing depth
Just had a well drilled a couple weeks ago, its a 6" casing , I had an old drilled well at 80' that went dry was only getting 1 gpm recovery . new well is 141' . only problem is I looked at the bill and it says they drilled 141' after 8' they hit limestone until 141' they only put 23' of casing in and the rest is just a hole in rock, is this normal? I thought the casing is supposed to be quite a bit farther down then that,
bricklayer is offline
Old 08-11-2013, 09:34 PM   #2
johnjh2o's Avatar
Liked 730 Times on 554 Posts
Likes Given: 624
Casing is only used until they hit rock. The main purpose of the casing is to prevent surface water from entering the well.
johnjh2o is offline
Old 08-13-2013, 01:23 PM   #3
Wells & pumps; not a...
speedbump's Avatar
Liked 211 Times on 192 Posts
Likes Given: 46
Where are you located?
Sounds like they went a long way into the lime rock that probably wasn't necessary. As porous as most limerock is, going that far to get a usable amount of water is overkill. It also makes it easy to have more hardness, iron, sulphur and other undesirables. I'll bet the rig was a Rotary.
speedbump is offline
PVC well casing questions stevehull Pumps and Wells 16 01-25-2013 11:36 PM
Well Water Depth Pikanjoe Pumps and Wells 3 02-06-2012 03:56 PM
Newest Threads
