Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Two tap shower problem...
Thread Tools Display Modes
Old 08-01-2013, 11:11 PM   #1
gepark
Default Two tap shower problem...
Hello all - I'm hoping you can help with this issue.
I have a stand-alone shower with two taps. There is a standard shower head with a diverter to a hand-held shower head. I'm guessing it is an original setup in the house, which makes it about 30 years old.
The hot water occasionally drops away, even though the cold tap is barely on and the hot is full on. It eventually comes back, but it can take a few minutes. Unfortunately, there is no access panel - drywall on one side, tile on the shower side.
There are two other showers in the house, and no problems occur with them. There is also an on-demand water heater.
Any thoughts on the cause of the hot water drop? I'll try to provide more information if needed.
Thanks!
G.
gepark is offline
Old 08-06-2013, 02:06 AM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
It could be possible that the shower head doesn't meet the minimum flow required or its so close to the minimum it sometimes won't activate the tank less unit. I'd remove the shower head and then run it and see if the issue still happens
stevemachine is offline
johnjh2o Likes This
Kohler shower faceplate problem Larry29 Showers and Tubs 5 12-15-2013 10:55 PM
Shower/Bath Problem Lilmiss911 General Plumbing Help 1 06-05-2012 12:02 PM
Shower drain problem hba123 Drain and Sewer Cleaning 2 08-03-2011 11:27 PM
Shower Head Diverter problem? standenman Showers and Tubs 3 02-03-2011 04:12 AM
Shower Controller replacement problem Golfish Showers and Tubs 1 01-23-2010 10:25 PM
Newest Threads
