Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > grey water ejector in basement funny smell
Thread Tools Display Modes
Old 08-01-2013, 09:01 PM   #1
cernigs23
Liked 1 Times on 1 Posts
Default grey water ejector in basement funny smell
I have a water ejector in my basement that takes water from the washer and utility sink. Im getting a funny smell and pretty sure its not sewer gas but something similar. The smell seems to be coming from the tank area. I siliconed the lid but hasn't fixed the problem. the tank is made of fiberglass. the tank seems to have some rust colored residue on the outside in some places. im assuming this is from moisture because the tank isn't air tight anymore. Any advice on what to do next. I tried installing a check valve but found out there was water in the ejector tube at all times. That made me think theres a check valve on the pump itself. My original thought that sewer gas was coming through the ejector pipe into the holding tank and coming through the lid. once I found water in the ejector pipe it didn't make sense that gas could travel from the 6" main line down to the tank. I have pics to better explain. Thanks
IMG_20130801_153838_898.jpg   IMG_20130801_153858_864.jpg   IMG_20130801_154018_571.jpg   IMG_20130801_154400_932.jpg
cernigs23 is offline
Old 08-01-2013, 09:24 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 712 Times on 541 Posts
Likes Given: 603
Is that a tee down near the tank in the tank vent? If so where is it going?
John
johnjh2o is offline
Old 08-02-2013, 03:02 AM   #3
cernigs23
Yes it is. It runs to a pipe sticking 4 inches out of the ground underneath the utility sink. I'm thinking the pipe runs to the ejector pit in the pretense of a bath installation in the future and the vent needs to be connected to it unless plugged. Now that's what I see... I'm not a plumber. I'm a former marine and now a firefighter. I have experience with rough carpentry and that's that. Thanks for looking.
Zanne Likes This
Old 08-02-2013, 03:11 AM   #4
cernigs23
I'm sorry the tee you're referring to is where the utility sink empties into the tank
Old 08-02-2013, 03:17 AM   #5
johnjh2o
johnjh2o's Avatar
Likes Given: 603
How about a picture of what you have on the other side of the wall.
John
johnjh2o is offline
LiQuId Likes This
Old 08-02-2013, 05:37 PM   #6
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
johns got ya covered but i do feel the need to mention that you would be better off without the furnco's ( rubber joints ) and instead solid glued joints.
perhaps a union IF you need to access the pipe. ferncos are not pressure rated beyond 5 psi and your pump will generate much more than that ( likely ) which could potenmtially be a smell problem if the ferncos are buldgeing and allowing a small bit of seepage over time.
more pics frm multiple angles and places would help.
LiQuId is offline
People Like This
Old 08-03-2013, 12:36 AM   #7
cernigs23
heres a pic of the other side of the wall. I hear ya on the rubber joints. there was a check valve there. im concerned that the pressure might be getting passed the lid on the tank. Cant be sure though. I siliconed the **** out of it.
Old 08-03-2013, 12:45 AM   #8
cernigs23
here are some more pictures
IMG_20130802_193832_127.jpg   IMG_20130802_193852_279.jpg   IMG_20130802_193936_645.jpg   IMG_20130802_194018_836.jpg
Old 08-03-2013, 01:48 AM   #9
johnjh2o
johnjh2o's Avatar
Likes Given: 603
I may be wrong but it looks like the line you're using to vent the sewer ejector is a waste line from a fixture on the floor above.
John
johnjh2o is offline
Old 08-03-2013, 05:27 AM   #10
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
The system is not setup 100 percent correct. The piping coming out the top should be for discharge and venting only, the waste inlet to the system is underground ( waste should enter through the side of the pit). The laundry tray/laundry sink is draining into the vent port of the system. I think the system is pipe this way-- The waste inlet is being used as a vent (meaning the cast iron under the sink is attach to the pit waste inlet).The pvc pipe tied to the cast iron pipe coming out the floor is a vent that has been ran above the cinder block to the exterior of the house or quick vent. The vent port of the pit is being used as the laundry waste inlet then revent to the vent. The discharge is what it is. I'm just assuming this is the configuration looking at the pics and not being there.
IFIXH20 is offline
Zanne Likes This
Grey Hazy Colored Water ajason Pumps and Wells 2 06-24-2013 04:46 AM
Smell of Sewage in Basement Apartment kjk05006 Septic Tanks 1 04-03-2013 09:14 PM
Basement Drain Smell/Repair jpm6621 General Plumbing Help 17 10-02-2012 10:11 PM
Ejector pump vent in basement bathroom dbbl21 Pumps and Wells 5 03-14-2012 12:13 AM
Grey Water Issue Silverman Plumbing Building Code 2 01-27-2010 07:33 PM
Newest Threads
