Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Project Display > Drain / Vent Layout Question
Thread Tools Display Modes
Old 07-26-2013, 01:07 AM   #1
philwgreen
Default Drain / Vent Layout Question
In the process of building a garage addition that has living space above. There is a single bathroom on the second story with a lav, toilet and shower. The bathoom is 12' long with the toilet and shower on opposite ends. The main stack will pass up through the wall next to the shower.
Just getting ready to start my rough in and wanted to run my dmv diagram past everyone here. My main questions are:
1. First off, does this diagram look correct or am I way off?
2. There is a utility sink on the first floor, I know I can't vent it using the bathroom lav drain but can it connect to the lav vent in the attic? And can that vent tie back into the main stack or does it need its own roof penetration? In my drawing I have it going up through the roof.
3. My toilet is roughly 12' from the main stack so I've added a vent. Would a 2" vent be sufficient for the toilet?
Any help/feedback is appreciated.
philwgreen is offline
Old 07-26-2013, 02:01 AM   #2
phishfood
Administrator
Liked 959 Times on 771 Posts
Likes Given: 1727
Under IPC, you can run an unlimited distance between the toilet and it's vent, no more 10' limitations. Also under IPC, that vent coming off of the toilet running flat is not allowed. Minimum vent size is 1/2 of the largest drain served, which in your case could be as small as a 3" drain, so 1 1'2" vent. Yes, you can revent the lower fixture vent into the bathroom vent in the attic, and yes, you can revent that vent into the main vent for the house.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 07-26-2013, 02:16 AM   #3
philwgreen
Thanks for the response. So it sounds like I don't actually need the toilet vent (we are under IPC here). Is there any danger that with no vent flushing the toilet could siphon any of the other traps?
Just edited my drawing. If I did want to vent the toilet - would it work like this?
Old 07-27-2013, 12:38 AM   #4
phishfood
Administrator
Likes Given: 1727
The toilet will vent through the lavatory vent, and since every other fixture is individually vented, there is no way for the toilet to siphon any of the other fixtures.
Old 08-07-2013, 05:32 PM   #5
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
what he said ^
REall phish ? unlimited distance ?? that seems odd zas it would make a double S trap after the 3" line exceeded 12' of distance at grade of 1/4 per foot.
our code in canada we need to have a vent ( usually the lav As a wet vent ) the tub must also come off of this wet vent ( 2" to the lav with a 2 x 1 1/2 for the tub ) or be individually vented.
LiQuId is offline
Old 08-07-2013, 11:46 PM   #6
phishfood
Administrator
Likes Given: 1727
Quote:
Originally Posted by LiQuId View Post
what he said ^
Yes, really.
Think about it, the very design intent of the toilet is to FORCE it to siphon it's own trap when flushing, and then the trap is refilled by the fill valve. And now consider that the only reason for the trap to be within a certain distance of it's vent is to stop it from siphoning itself, and you can see why that code change was made.
LiQuId Likes This
Old 08-08-2013, 01:56 PM   #7
LiQuId
Likes Given: 20
i suppose so but that syphoning happens due to the integral S trap, having one further down the line seems odd to me though I DO see what you mean.
LiQuId is offline
Vent pipe question... 1234 Plumbing Building Code 4 06-06-2013 04:49 AM
Drain/Vent Question mwb31 General Plumbing Help 6 04-29-2012 02:47 AM
Layout/Design Question MrVVhite General Plumbing Help 1 03-15-2012 03:41 PM
vent question dlangdon50 General Plumbing Help 4 05-20-2011 01:51 AM
another vent question bridgeboy General Plumbing Help 4 07-17-2010 10:55 AM
