Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > HELP! New Sink set up?
Thread Tools Display Modes
Old 07-24-2013, 06:01 PM   #1
mcintoshmc
Established Member
Default HELP! New Sink set up?
Okay, I had new countertops along with a new sink in stalled. i assumed that I would just be able to mimic the old set up prior to the install, but I was wrong.
I had to purchase new flanges because they took my old ones when they disposed of my old sink. I have attached photo of before and after. I bought a new 6 in tail piece looking to mimic the old setup, but the tail piece doesnt align with the p-trap. I went to lowes 4 times trying to figure this out, and what I ended up doing just to get the sink operational was slide the p-trap up the tail piece about 2-3 inches, and then force the tail piece towards myself, so that I could slide the end of the p-trap to align with the pipe coming from the wall.
In doing this, I moved the flange exposing more of the putty in the sink, and creating a leak. I currently have a bucket under there.
How can I fix this?
new sink old setup.jpg   new sink with 6 in tail piece.jpg   new sink opening with old set up.jpg   new sink old setup2.jpg
mcintoshmc is offline
Old 07-27-2013, 10:24 PM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
You cut the drain off altogether, on the horizontal part then
use a transition coupling (rubber) and go to pvc/abs. You would need the transition coupling to go from 1 1/2 copper to 1 1/2 pvc/abs and then get a union trap 1 1/2 and a 1 1/2 trap adapter. That's how I would do it.
stevemachine is offline
Garbabge Disposal Sink & Other Sink back up water 88al88 Toilets and Sinks 3 07-18-2012 12:54 AM
Changing from single sink to double sink in bathroom keith5523 Toilets and Sinks 1 09-25-2011 02:32 PM
Kitchen sink drains extremely slowly and backs up (double sink) TimeForAction General Plumbing Help 6 10-22-2010 07:46 AM
Strange sink stainer size on cast iron sink jemicha Toilets and Sinks 3 04-15-2010 10:36 PM
Newest Threads
