Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > how to install gas shutoff valve flush in wall behind gas range
Thread Tools Display Modes
Old 07-19-2013, 08:34 AM   #1
joecm3
Default how to install gas shutoff valve flush in wall behind gas range
Hi there,
Just installed a gas range, but realize the gas shutoff valve is 3" out from the wall (26 1/2" height) so the gas range cannot be flush to the wall.
Click image for larger version
Is there a way to modify the gas shutoff valve such that it's inside the wall/flush along the wall so the gas range can be flush to the wall?
I don't see product like a gas valve box.
Any suggestion?
Thx.
joecm3 is offline
Old 07-19-2013, 10:59 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 723 Times on 547 Posts
Likes Given: 616
What needs to be done is to relocate where the line exits the wall according to the specifications for your particular range.
John
johnjh2o is offline
Old 07-19-2013, 11:59 AM   #3
ricvan
Liked 1 Times on 1 Posts
and have the shutoff facing out for easy access
ricvan is offline
Old 07-19-2013, 12:02 PM   #4
ricvan
most appliances require a space away from combustables at the back of the units...check your manual for this first before doing all that extra work...if your gyprock is not at least 5/8" fire rated then you will prob have to have an air space back there anyway
ricvan is offline
Old 07-19-2013, 02:11 PM   #5
joecm3
Quote:
I'm trying to find a way to keep from moving where the supply gas line comes up from the crawspace.
As you can see the install manual recommends area height for gas valve/outlet to be between 7" to 15".
Name:	Gas Range - install - page 4.jpg
I can at least lower the gas valve location to that level. However, the gas valve is 3/4 you can see I downsized it to 1/2" size. The supply gas line at the back of the gas range and the pressure regulator are also around that area so I'm not sure if it could still be in the way and I'd have to bend the flex pipe right there which I don't want to do.
Name:	Gas Range - back.jpg
The better location is on the other side of the wall where it's away from the gas supply line in the back of the gas range, but I'm trying to avoid moving the gas line from the wall's location horizontally as that'd mean I'd need to move the branching location coming from the crawl space down below and that's too much work.
joecm3 is offline
Old 07-19-2013, 02:23 PM   #6
johnjh2o
johnjh2o's Avatar
Likes Given: 616
If you want the range to set back to the wall your going to have to move the gas line.
John
johnjh2o is offline
IFIXH20 Likes This
Old 07-19-2013, 10:16 PM   #7
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
I agree with John the line needs to be moved/lowered. You may not have to move the line from it's location( the hole the line is coming up through in the wall) if you can get away with a shorter riser/nipple. Open the wall behind the stove to see if there is any fitting on the line, then check the crawl space to make sure the rise/nipple can be removed. If you can remove the riser/nipple take a measurement of the height you need to the hardware store they should be able to cut and thread the piping to your size. Make sure you have a drip leg on the line as well.
IFIXH20 is offline
Old 07-20-2013, 04:11 PM   #8
joecm3
Is it acceptable to run the gas line horizontally (across the studs) to the left of the wall after the riser and the gas shutoff valve at the end (on the left)?
That way the shutoff valve would be far away from the pressure regulator. There would be a lot more room.
joecm3 is offline
Old 02-01-2014, 07:17 PM   #9
pcride
Established Member
Liked 8 Times on 8 Posts
best thing to do is cut out the sheet rock, you may be able to move the gas line back by notching out the floor plate, then turn your valve. you can find a box to put it in.
pcride is offline
Leak from toilet shutoff valve Kissimmee General Plumbing Help 3 04-01-2014 11:15 PM
Shower Base flush to wall? Bogucki Showers and Tubs 16 11-20-2013 03:20 PM
Washer Machine Shutoff Valve ccg19072 General Plumbing Help 5 02-26-2012 12:00 AM
Is there a way to fix this dripping shutoff valve? ecrane99 General Plumbing Help 5 07-29-2011 05:02 AM
Shutoff Valve siezed abhi General Plumbing Help 3 11-09-2010 06:07 AM
Newest Threads
