Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Never ran into this one before
Thread Tools Display Modes
Old 07-17-2013, 12:10 AM   #1
phishfood
Liked 938 Times on 754 Posts
Likes Given: 1672
Default Never ran into this one before
Sold and installed an electric water heater a couple of months ago, the customer did the startup as he didn't have water or electrical turned on yet. Got a call, either VERY hot water, or no hot water and ECO (red reset button) is tripped.
I checked power, thermostat settings (both were set to 125). No power fed to upper element, the bottom element had power and was heating. I drew some water from the T&P valve, it was only reading 110. I played with the upper thermostat setting. To get it to send power to the element, I had to set it to 140. So I knew it was bad, changed it, and the upper element energized and started heating. But the extremely hot water and the tripped ECO was bugging me, couldn't figure out why those had been occurring.
After thinking it through, here is what I think was happening. The upper thermostat was obviously reading incorrectly, so it was never sending power to the upper element, so the water toward the top of the heater was not getting hot before the bottom element turned on. The bottom element stayed energized, and was continuously heating water, but the bottom thermostat was never cutting power to it because the hot water was displacing to the top of the tank. The water at the top of the heater was getting very hot, up until the point that it was tripping the ECO.
Whatchya think of my conclusion?
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 07-17-2013, 02:52 AM   #2
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Phish,The problem may have stem from the lower t'stat. Usually what happens is the lower t'stat contacts weld themselves together from arching when closing due to electricity passing through them (it's not a very strong weld) once lower t'stat contacts are stuck/weld closed the lower heating element heat continously to the upper t'stat eco/limit switch trips. The contacts may even open after sticking/welding. I have found this to be more common on the t'stats that have letters(temp setting) on them. This is a common problem I find that lots of tech overlooks. The top t'stat/ heating element is the master and the lower is the slave, if the unit is not heating up top first the lower should not come on.
IFIXH20 is offline
phishfood Likes This
Old 07-17-2013, 02:58 AM   #3
phishfood
Likes Given: 1672
I did check the operation of both thermostats before deciding to replace the top one. Adjusting the bottom one down to it's lowest setting cut power to the lower element.
In this situation, the upper thermostat was thinking that the top of the tank was already heated up, due to the faulty reading the thermostat was taking.
Thanks for bringing that up, though. It could very well save me some hair pulling one day.
Old 10-06-2013, 10:25 AM   #4
robmcg
Liked 1 Times on 1 Posts
[QUOTE="phishfood;45350"]Sold and installed an electric water heater a couple of months ago, the customer did the startup as he didn't have water or electrical turned on yet. Got a call, either VERY hot water, or no hot water and ECO (red reset button) is tripped.
Did u consider the owner may have powered the tank without filling it or possibly filling it halfway and burning something up? Seen something similar b4 except I was the knucklehead ; )
robmcg is offline
Old 10-06-2013, 01:24 PM   #5
phishfood
Likes Given: 1672
Quote:
Originally Posted by robmcg View Post
Actually, I have become convinced that is EXACTLY what happened. I ended up getting called back again, because of no hot water. Both elements were fried, which I have only ever seen on a new water heater because of dry firing.
My bad, I should have never installed the heater without the ability to fill it with water right then and there. Never again.
Old 10-06-2013, 09:57 PM   #6
robmcg
[QUOTE="phishfood;47714"]
A painful lesson we both learned the hard way. Thankfully a mistake u only make once
robmcg is offline
Newest Threads
