Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Help needed - identify this bathtub valve stem
Thread Tools Display Modes
Old 07-06-2013, 10:56 PM   #1
Nicholas440
Established Member
Default Help needed - identify this bathtub valve stem
Hello all,
I'm new here, and I wanted to replace a washer in my bathtub fixture as it was dripping slowly for some time now. I removed the knob and trim bezel, it was very hard to get the knob off because I believe it's been on for about 30 years or more. The house was built I think in 1952 , and when I took off the knob and trim, I knew I had a problem because I've never seen a faucet like this one. In the past I have changed a washer in a bathtub fixture, and I have a set of those deep socket tools to unscrew the stem, however this one is different.
This valve appears to be a cast brass large round piece that protrudes out of the wall slightly, and has a brass nut on the end that unscrews . I took the brass nut off and I was going to insert one of the sockets and unscrew the stem, but the hole that is around the stem is only about a 5/8 diameter hole and if I look in there with a flashlight, the stem is very long, I'd say aout 4 inches, and there is no nut down inside there to unscrew, so I'm at a loss on how to change this washer. I tried to count the splines on the end of the stem, and I think I count 16 spines not positive as it's hard counting them when you need new glasses.
Can anyone tell me what brand this might be? There is no name on the fixture all it says on the shower pull up knob is Made in USA, pull up for shower. The handles look like American Standard, I enclosed a few pictures to help identify this fixture. Also if you know what it is, can you tell me how I get the stem and washer out? It would not surprise me if it takes a special washer, I have a few packs of assorted standard faucet washers, hopefully it uses a common flat washer like the one I did about a year ago for my brother.
Thanks in advance for any help and info on this fixture.
Nick,
bathtub stem.jpg   Pic B of stem on bathtub.jpg   Pic C of bathtub knobs.jpg   Pic A of bathtub stem.jpg
Nicholas440 is offline
Old 07-06-2013, 11:43 PM   #2
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
Likes Given: 1
Can't help you in the model , but your just undoing the packing nut. Try to remove the bigger nut and see if it comes out
camaroderrick73 is offline
Old 07-07-2013, 03:37 AM   #3
Nicholas440
Established Member
Thank you.. I tried to remove the larger nut but it's part of the large brass casting. I believe the larger hex nut is there just to hold the whole thing still while you unscrew the packing nut otherwise the entire brass unit in the wall could turn and break.. but thank you for your reply...
Old 07-07-2013, 12:44 PM   #4
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
The handle looks like the old American Standard Heratage line but the stem isn't. But like stated above the large nut must be removed to remove the stem. The reason you may be having a problem removing it is because you have stem is in the off position. Try turning the stem on.
John
johnjh2o is offline
Old 07-07-2013, 03:50 PM   #5
plbgbiz
plbgbiz's Avatar
Liked 65 Times on 46 Posts
Likes Given: 84
You have to turn the stem as if you have the water on or it will not unscrew.
plbgbiz is offline
Old 07-08-2013, 01:41 AM   #6
Nicholas440
Established Member
Thank you for all your replies. I turned the valve stem clockwise, inward, and then I put a wrench on that large hex and gave it a turn, and it came loose, so actually the large hex does come off, and the stem comes out when I turn it clockwise, so I was able to get it out.
My only concern is that the entire end piece that holds the washer on swivels around and its' loose , it appears as if it's made to rotate. The washer screw was on nice and tight, and of course the washer is shot it's hard as a rock and has a good round groove in it from the valve seat over time.
Im just wondering is this end piece on the stem supposed to rotate? Does anyone know if it's normal? Tomorrow I have to take the stem to the hardware and match up a washer for because the washer is about 7/8 diameter flat rubber and about 1/8 inch thick. All the standard faucet washers I have in my tool box are much smaller, for normal sink faucets.
Here is a photo of the stem I took out. Maybe it's an American Standard or American Heritage? Either way it's probably about 60 years old.
Old 07-08-2013, 02:08 AM   #7
johnjh2o
johnjh2o's Avatar
Likes Given: 620
Good job. Some stems have washer retainers that rotate looks like you have one. Be careful removing the old bibb screws. If it doesn't come out easily cut as much of the washer out as possible. That will help to free the bibb screw up. Be sure to replace the bibb screw as well as the washer.
John
johnjh2o is offline
Old 07-12-2013, 04:28 PM   #8
Another-Plumber
Another-Plumber's Avatar
Liked 6 Times on 5 Posts
Likes Given: 4
crane? check the "partsmaster" book for for sure match
Another-Plumber is offline
Old 07-12-2013, 11:19 PM   #9
camaroderrick73
Likes Given: 1
Where can u get a parts master book?
Old 07-13-2013, 04:18 AM   #10
Another-Plumber
Likes Given: 4
if you still need help on this, ill identify it for you in the morning... would be nice to see the stem closed if you can
Advice needed - slow draining bathtub scrabble General Plumbing Help 6 07-07-2013 07:48 PM
Help identify old bathtub faucet stems Kern General Plumbing Help 2 04-10-2013 12:21 AM
Help, Can you identify Valve Brand? wbatten Showers and Tubs 1 03-07-2013 05:16 AM
Can anyone ID this shower valve stem? mmuratet Plumbing Products 2 07-25-2011 12:59 AM
How to remove valve stem in single handle bathtub faucet. wndrwmn67 Plumbing Tools and Equipment 20 03-12-2011 06:51 AM
Newest Threads
