Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Hex nut on shower drain wil not stay tight
Thread Tools Display Modes
Old 06-12-2013, 03:21 AM   #1
tbakbradley
Default Hex nut on shower drain wil not stay tight
Hi folks. Last year, I was in my basement when water started pouring from the ceiling. Luckily, it's a drop ceiling. The hex nut was completely loose. I tightened it by hand. Started leaking the next time someone stepped into the shower. The nut was loose again. I assumed it was due to not being tight enough. However, I didn't A) know how tight it should be nor B) what to use to tighten it. It's large and I don't have a wrench that big. I then put a screwdriver into the slots on the hex nut and took a hammer to tighten it. Good for a couple days, and then loose again. Like anytime someone steps into the shower, it loosens.
Someone told me to loosen it, so I could pull the drain up at the shower. Place plumber putty between the drainer piece and the shower. It would help sill it AND extend the drain up a hair, to pull the hex nut tight.
Ok...that worked or so I thought.
Fast forward to today and here came the water. The drop ceiling tile was soaked and moldy. So, it had been leaking a while, meaning my old "fix" didn't really work.
Can anyone help me?
This is not mine, but found on the net, but my hex nut is like this, where it is leaking.
Click image for larger version
tbakbradley is offline
Old 06-12-2013, 10:51 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 684 Times on 518 Posts
Likes Given: 572
You can try loosing it again and use silicone instead of putty. But it sounds like your problem is a soft floor in fiberglass shower.
John
johnjh2o is offline
Old 06-12-2013, 11:38 AM   #3
tbakbradley
Quote:
Are you talking silicone in a caulking bottle, or something different?
A friend told me to cut out that piece of PVC and install a flexible piece that will give when the floor moves.
Old 06-12-2013, 12:26 PM   #4
johnjh2o
johnjh2o's Avatar
Likes Given: 572
The point is the floor shouldn't move.
John
johnjh2o is offline
Old 06-13-2013, 02:49 PM   #5
tbakbradley
Looks like I will need to brace it somehow
Old 06-14-2013, 01:15 AM   #6
plbgbiz
plbgbiz's Avatar
Liked 65 Times on 46 Posts
Likes Given: 84
Gonna be a tough fix without removing the shower. Someone tried the quick fix already that has apparently failed. (spray foam)
plbgbiz is offline
Old 06-14-2013, 02:15 AM   #7
AQualityPlumber
Plumber
AQualityPlumber's Avatar
Liked 13 Times on 11 Posts
I have ran into this problem many times and hence why I will not install this type anymore. No matter what you do it will leak sooner or later. To permanently fix this you must actually scrap the current drain configuration all together.
Now there is 2 options:
Option one is the cheapest but much harder to do. You will need a drain that is designed in a manner where the compression nut is only compressing the drain to the shower base. The pipe connection needs to glue in. When installing the drain to the base make sure to use a liberal amount of pure 100% silicon. This method will eliminate the compression nut making the seal between the drain and the pipe.
Option 2 is a more expensive drain piece but easier to install and in my opinion well worth the money. Brass craft and similar product lines make a pure brass compression drain. You will still use a liberal amount of silicon but this brass drain will come with a rubber doughnut and a threaded brass ring with a key. After attaching the drain correctly to the base, you will insert the pipe through the drain, pack the doughnut and tighten the threaded ring from above inside the shower with the key. Special note that it is extremely important your pipes penetration is perfect because the rubber doughnut is not very deep. Also put just a nice even amount of silicon on the doughnut to help it slide in easy and allow it to cure. If this is all done correctly you should not have anymore leaks. However this will not correct the floor flexing problem. That is a structural issue and may require removal of the shower base to fix correctly. Hope this article helps. Find more of our how to plumbing at our blog.
A Quality Plumber Inc.
www.PlumbingWA.com
www.plumbingwa.blogspot.com
Last edited by havasu; 06-14-2013 at 03:39 AM. Reason: improper URL deleted from body of text
AQualityPlumber is offline
Old 06-14-2013, 02:20 AM   #8
AQualityPlumber
Plumber
Oh yeah and whatever you do do not spray foam. I repeat do not spray expanding foam. Reasons are as follows.
1 - as soon as it expands it can potentially lift the base and unlevel it if the base is the thick and secured right.
2 - once the foam expands, hardens, and a 200lb person steps on top of it, it will must likely crush and do no good for support.
3 - worse come to worse you have to hire a plumber to fix this, he will be pissed that he has to dig out a bunch of crappie foam to fix it. He might even charge you more. I would anyways.
www.PlumbingWA.com
Old 06-14-2013, 02:28 AM   #9
AQualityPlumber
Plumber
For cranking this nut, there is a special wrench for torquing the nut. You will only find it at the plumbing supply house. I also have a 24" pair of knipex channel locks that will expand and do a great job at tightening a nut this big. Only down fall is the channel lock is about $100.
www.PlumbingWA.com
Old 06-14-2013, 07:50 PM   #10
tbakbradley
Quote:
Thank you for all this info. I'm nervous to call a plumber in my area as I'm not so sure many know what they are doing. In fact, I had a licensed plumber to install a Watts Regulator. Once at my house, he told me I didn't purchase the correct regulator with the correct endings. After he told me that, I didn't want him touching my plumbing. A week later, I installed the regulator. This is the same person who suggested I use a flex pipe on the shower drain.
Prior to this plumber, I called another popular (and very expensive) outfit to install a new water hose bib that burst. The valve of the old one was inside the wall (had opening for access). The one he installed stuck out 4 inches inside my basement and leaked within a year. I fixed it this summer.
So, with all that said, I don't have high hopes anyone in my area has the know how to understand your fix. Sad thing is, BOTH plumbers I used were recommended by folks I know.
I don't know much about plumbing, so not sure I could do either of these jobs unless I watched a How To video, or had some links to the parts I need. Could you point me to some info on your options?
Faucet won't stay on (video) xfactor General Plumbing Help 7 02-23-2014 07:47 PM
Pilot light will not stay lit. jeff Water Heaters and Softeners 30 07-13-2013 04:15 AM
Taps too tight emilybieman General Plumbing Help 2 06-11-2012 09:38 PM
Tight faucet handle yong321 General Plumbing Help 3 05-24-2012 12:15 AM
tub P trap in a tight space? Copper Showers and Tubs 2 01-20-2011 01:57 AM
Newest Threads
