Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > White particles in tap water
Thread Tools Display Modes
Old 05-31-2013, 04:26 AM   #1
joni
Default White particles in tap water
Hi Everyone! Hope to get some answers here...Every month I have to remove my faucet screen on tap because water pressure is low. Every time it is due to little white pieces of stuff clogging the screen. I think it is a build up of something in my pipes. Does anyone know what this is and if there is a DIY solution to this or is it time to call a plumber?
Thanks
Joni
joni is offline
Old 05-31-2013, 04:38 AM   #2
chukar
Liked 20 Times on 18 Posts
Do you have hard water? Are you on city water or well, also is your home newer piped with plastic pex or older using galvanized piping, easy method look at piping under your sinks and by the water heater.
chukar is offline
Old 05-31-2013, 04:49 AM   #3
joni
It is hard water and I am in the city. I checked and my pipes are copper out of the water heater. There is a part on the pipe that is corroded as well and has what looks like battery acid on the foam that wraps the pipe.
joni is offline
Old 05-31-2013, 05:35 AM   #4
camaroderrick73
camaroderrick73's Avatar
Liked 30 Times on 29 Posts
Likes Given: 1
Could be your dip tube deteoriated from the water heater....
camaroderrick73 is offline
johnjh2o Likes This
Old 05-31-2013, 10:40 AM   #5
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
Quote:
That's what it looks like to me but the problem with dip tubes was solved long ago. I guess there could still be some of the old ones around. Just how old is the water heater?
John
johnjh2o is offline
Old 05-31-2013, 12:36 PM   #6
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Place the particles in white vinegar if they dissolve they're hard water particles if they don't dissolve they're dip tube particles.
IFIXH20 is offline
People Like This
Old 05-31-2013, 02:18 PM   #7
joni
My GSW water heater's serial number is 9902289926 so what I've learned is a 1999 model. How long should they last?
Thanks for replying.
Joni
joni is offline
Old 06-01-2013, 06:30 PM   #8
IFIXH20
HERE TO HELP
Likes Given: 165
Joni
Your water heater is past or at it's life expectancy. Water heaters life expectancy is 8-15 Years depending on where you live , water quality ,usuage ,etc. Your water heater could very well fall under the time we where having the dip tube issues. Most water heaters with dip tibe issues had a cut off time around 1997 but there was some with a cut off time of 1999. Look like it's time to replace.
IFIXH20 is offline
Old 06-02-2013, 03:19 PM   #9
joni
Thank you IFIXH20. I put the particles in vinegar and they are not dissolving when I stir it around but they will crush easily into smaller pieces. If it is the dip tube eroding, would the plastic from the dip tube crush that easily?
Also I found a GE 12yr warranty water heater on sale for $163.00. I think I should just purchase even if my water heater is repairable, I've got a new one for the future and at a really good price.
What do you think?
Joni
joni is offline
Old 06-02-2013, 05:20 PM   #10
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
Just curious joni, where did you find that tank for $163? The gas model typically retails for $550-$600. If you found it online through a third party seller, you will want to be sure that the manufacturer will still honor the warranty, the tank isn't already used and that it's not a bootleg version of the original tank. Just looking out for you. Rheem makes GE tanks. If you can get a model and serial number of the tank before you purchase it, their customer service may be able you verify that it's a good warrantied heater.
Rheem customer support: 1-866-720-2076 Available between 7AM - 7PM Central Time 7 days a week
Caduceus is offline
havasu Likes This
white drain pipe 220ws General Plumbing Help 6 03-13-2012 12:20 AM
White flakes coming from refrigerator water hose only slavrenz General Plumbing Help 8 03-07-2012 11:26 PM
Black particles in water tazfan Pumps and Wells 21 12-31-2011 08:08 AM
Particles of rubber (from pressure tank) in water? Vincent Pumps and Wells 4 09-02-2011 05:50 PM
Particles in water Candlestick Pumps and Wells 5 01-05-2011 07:16 PM
Newest Threads
