Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Can someone identify these fittings
Thread Tools Display Modes
Old 04-15-2013, 04:42 PM   #1
neoteric5
Likes Given: 1
Default Can someone identify these fittings
I just moved into a new apartment and found these two fittings/valves under the kitchen sink. They are about 6.5" long appear in the 1/2" supply lines that emerge from the plumbing riser, between some shutoff valves and the kitchen faucet and dishwasher supply lines. Can someone please tell me what they are?
I am planning to renovate the kitchen and these valves are somewhat large and in the way. I'd like to eliminate them, but not before I know why they are there. :-)
Thanks in advance!
neoteric5 is offline
Old 04-15-2013, 05:59 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1114 Times on 906 Posts
Likes Given: 336
They appear to be water hammer arrestors.
havasu is offline
neoteric5 Likes This
Old 04-16-2013, 01:41 AM   #3
neoteric5
Likes Given: 1
Hmm. Okay, well if someone felt the need to install these sometime in the past, there must have been a water hammer problem at some point. I guess I should leave them in place.
Thanks for your help!
Old 04-16-2013, 03:43 AM   #4
havasu
Administrator
havasu's Avatar
Likes Given: 336
You are correct, but you may find a better location to mount them than under your sink.
havasu is offline
Old 04-16-2013, 04:11 AM   #5
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
And I'm betting if they're that old, they probably don't even work anymore. It definitely doesn't hurt to have them in your home but you could put them anywhere that's accessible for you
stevemachine is offline
Old 04-16-2013, 12:01 PM   #6
johnjh2o
johnjh2o's Avatar
Liked 722 Times on 546 Posts
Likes Given: 615
I'm not so sure they are hammer arresters. Back in the day of threaded brass pipe air hammer wasn't a problem. I have seen them before but I can't remember what they are. (it's tough to get old)
John
johnjh2o is offline
Old 04-19-2013, 11:54 AM   #7
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
The valves appear to be old lockable gate valves, If you notice the top piece is a different brass than the body. If i'm not mistaken the top piece/cap should come off to access a square stem to turn the valve on & off.
IFIXH20 is offline
Old 04-19-2013, 02:19 PM   #8
havasu
Administrator
havasu's Avatar
Likes Given: 336
Now you guys have me wondering about my initial assessment. I sure hope the OP comes back and provides us more information.
havasu is offline
Old 04-19-2013, 07:38 PM   #9
neoteric5
Likes Given: 1
When I get home tonight, I'll try to pop off the top cap. But considering the only things on the other side of these pipes are a kitchen faucet, a dishwasher and a fridge, I wonder why anyone would want a locking valve here?
Old 04-23-2013, 04:47 PM   #10
ballvalve
Those look like Pressure Reducing valves
Often installed for bathrooms and water heaters
ballvalve is offline
Can you identify this kitchen faucet? (pic) emy Toilets and Sinks 8 06-12-2012 03:59 AM
NEED HELP PLZ Identify verbl General Plumbing Help 9 10-25-2011 02:33 AM
identify product davidb Plumbing Products 3 06-30-2011 03:00 PM
Help Identify this Part abacus822 Showers and Tubs 3 12-29-2010 07:07 PM
Newest Threads
