Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Showers and Tubs > Add a basement shower
Thread Tools Display Modes
Old 01-06-2010, 12:54 PM   #1
progpen
Default Add a basement shower
We will be finishing our basement in the next 6 - 12 months and I have a question about shower drains. The basement has a bathroom roughed in, but there is no rough in for a shower, only a toilet, and what looks like 2 vanities (1 1/2 vented) that are about 2ft apart.
My question is, can we install a shower drain without tearing up the floor? The ceiling is 7'10" and the floor will be tile. Can I build a stand for the shower and tie the drain into the 1 1/2 that is roughed in above the floor line as long as I keep the slope at 1/4" p/f or more? The drain line could then be hidden in the wall.
If this cannot be done, then I'll need to remove the concrete and tie in.
T.I.A.
progpen is offline
Old 01-07-2010, 10:40 PM   #2
Local16 Omaha
Your #2 is my #1
UPC(Uniform Plumbing Code) requires a 2" drain for showers.
I would NOT drain a shower with inch and a half pipe.
Upc also requires a 1-1/2" vent for a shower. In my jurisdiction you don't have to vent it if you tie into a horizontal main.
Local16 Omaha is offline
Old 01-07-2010, 11:22 PM   #3
Montybell
Quote:
Is that based on thew volume of water it can hold? What would be the disadvantage of the 1 1/2?
Montybell is offline
Old 01-08-2010, 07:56 PM   #4
Local16 Omaha
Your #2 is my #1
I believe it is based on how much water an average shower puts out.
I don't think 1-1/2" would be able to keep up.
Old 01-08-2010, 08:05 PM   #5
progpen
Thank you. I figured as much, but wanted to make sure.
progpen is offline
Tags
DIY, bathroom, basement, drains, rough in
adding a basement shower gregol1962 General Plumbing Help 1 01-12-2012 03:04 PM
Help with my basement rough-in vader General Plumbing Help 7 12-26-2011 08:58 PM
Sink in basement mac_addict Toilets and Sinks 1 08-27-2011 09:35 PM
No rough in in the basement Cimco General Plumbing Help 2 01-30-2011 06:10 PM
Basement plumbing help yyaassoo General Plumbing Help 2 03-11-2010 07:17 AM
Newest Threads
