Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Spigot in front of pressure regulator??
Thread Tools Display Modes
Old 03-28-2013, 05:59 AM   #1
mcintoshmc
Established Member
Default Spigot in front of pressure regulator??
I finally finished my repipe. It took 3 1/2 days, and I moved the water heater outside. Everything turned out fine, except for the water pressure when the backyard spigot is turned on. Prior to the repipe I couldn't shower and water grass at the same time because the spigot was tied into the same line with the potable water.
My setup in front of the house consists of 2 cold water lines coming in. 1 comes in 3/4 going straight back the spigot, and the other goes through the regulator and feeds the house.
After I finished up, I hooked up a gauge and I have it set to 80 psi, but when I turn on the backyard spigot, it drops to 40 psi.
Why is this happening?
mcintoshmc is offline
Old 03-28-2013, 06:02 AM   #2
mcintoshmc
Established Member
I've included a photo
Old 03-28-2013, 06:15 AM   #3
mcintoshmc
Established Member
FYI, pressure is 120 psi coming from the street without a pressure regulator.
Old 03-30-2013, 03:14 AM   #4
mcintoshmc
Established Member
Any ideas??
Old 03-30-2013, 11:32 AM   #5
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Quote:
Originally Posted by mcintoshmc View Post
Any ideas??
That appear to be a gate valve in the pic, If the gate valve is old I would start with replacing it due to the fact the gate stem may be broken and the gate has drop abit causing a flow restrict. If the service entrance valve is new I would move the Hose bibb tee further up the water service.
IFIXH20 is offline
Banging pipes: air or pressure regulator or ? Chart General Plumbing Help 20 03-15-2013 12:07 AM
Softener/Pressure Regulator Positioning thriftyhiker Water Heaters and Softeners 3 01-10-2012 01:11 AM
What size Water pressure regulator do I need? trammd General Plumbing Help 1 11-10-2011 12:11 AM
Pressure Regulator Seat skiwater9 General Plumbing Help 0 06-28-2011 07:46 PM
Newest Threads
