Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > No air pipes in upstairs bathroom
Thread Tools Display Modes
Old 03-12-2013, 02:21 AM   #1
psychi
Default No air pipes in upstairs bathroom
While examining the plumbing in my upstairs bathroom I noticed there are no air pipes. It is a straight run of about five feet of 4" PVC pipe . It starts with the toilet followed by sink drain before it turns downward into the stack.
The bath drain comes into this straight pipe perpendicular.
I would want to add a an air pipe that vents through the roof. My question is does it matter where the air pipe is added? Some parts of this run are more accessible than others. I am aware that new building code says an air vent should be at every drain but that is not very doable. So where would be the most effective place to add a single pipe ?
psychi is offline
Old 03-12-2013, 03:21 AM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
Pictures if possible and it's wet vented. You can drain a tub and sink into a stack and vent the toilet, sink and tub through that entire stack. If its not going to outside air that's very surprising. If its 4" you should technically increase one size before you penetrate the roof, so a 4x6 coupling. At least in my area that's what we do.
stevemachine is offline
Old 03-12-2013, 03:23 AM   #3
stevemachine
Likes Given: 97
And put your vent as a continuation of the stack. Where is it venting right now? It's not capped is it ? And also toilet must be the lowest connected fixture in a wet vent and anything draining beneath that toilet say first floor has to be separately vented
Old 03-12-2013, 01:10 PM   #4
psychi
Thank You
From what I am reading it sounds like your recommendation is to put the air vent as close to the stack as possible and the further recommendation to bring the system up to code. Although I can appreciate the bring it up to code advice that would require far more construction and expense than I am willing to spend right now. From my perspective I am least attempting to bring it closer to code than what I started with.
I noticed the problem while looking at a vent pipe rising through the attic ceiling. The other end however was just buried, unattached in some insulation. Probably to fool house inspectors. I intend to run this pipe into the closed system mentioned above. It will at least offer some venting. It then becomes the question of where to insert it.
Thank You for your help.
psychi is offline
Old 03-12-2013, 04:47 PM   #5
stevemachine
Likes Given: 97
Yeah just do what you can I suppose, eventually get it done properly but it'll make it better than what you have.
Old 03-14-2013, 03:11 AM   #6
Beni
Liked 15 Times on 14 Posts
I would connect a 2" vent pipe to a new tee at the sink drain and extend up to to the existing roof vent that's in the attic. With the 4" waste, which is good size for a bathroom group the single vent will keep the lav and shower from siphoning..
Beni is offline
phishfood Likes This
Old 03-14-2013, 03:48 PM   #7
psychi
Well thats a possibility - it would just require cutting of the sub floor in order to gain access. Some of this run can be easily accessed from the room below , however that area would be more challenging.
psychi is offline
Old 03-15-2013, 12:28 AM   #8
phishfood
Liked 938 Times on 754 Posts
Likes Given: 1675
Can you post pictures of what you have now? I am having trouble envisioning what your system currently looks like.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 03-15-2013, 02:44 PM   #9
psychi
It is really a simple system. Imagine a 7. The long vertical line is the stack pipe. The short horizontal line has a toilet at the furthest end and a sink drain close to the stack pipe. The bath line is a perpendicular line intersecting the short line ( between the toilet and sink drain).
That's it. By the way I have never had a problem with gas odor or drainage.
psychi is offline
washer hookup upstairs skoby General Plumbing Help 9 06-09-2012 07:26 AM
Clogged Bathroom Sink Pipes + Broken Nipple Threads Massi Drain and Sewer Cleaning 8 04-08-2011 11:49 AM
Too much water pressure upstairs tgoodgame General Plumbing Help 4 01-27-2011 01:21 AM
Bathroom Pipes - Loud Tapping Sounds at Night, Please Help! amonson1984 General Plumbing Help 7 12-28-2010 04:21 PM
no hot water in upstairs showers????? jed General Plumbing Help 1 03-03-2010 11:12 PM
Newest Threads
