Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > New Sink Garbage Disposal P Trap Issue
Thread Tools Display Modes
Old 03-06-2013, 04:30 AM   #1
RichG
Default New Sink Garbage Disposal P Trap Issue
I'm in the process of installing a new sink which has deeper basins than the previous sink. Because the basins are deeper the garbage disposal's outlet now sits lower than the outlet pipe into the wall.
My questions are:
1. Is it ok if the disposal outlet is lower than the wall outlet? If not, will I have to tear into the wall to mount a new outlet pipe?
2. If it is ok to leave as is, I'm having trouble finding a set of PVC slip fit pipes that will work. The standard 1-1/2" P Trap kit I picked up has a wall pipe with about a 1" extension to the flange off the bend. I really need something that extends down about 4" off the wall pipe. Does something like this exist? I've been searching around but can't seem to find anything. If it doesn't exist, does someone have any recommendations on what to use?
RichG is offline
Old 03-06-2013, 11:39 PM   #2
phishfood
Liked 483 Times on 393 Posts
Likes Given: 649
No, that is not something that should be hooked up and left like that. Drainage water will sit inside of the disposal and smell to high heaven. Not to mention that it will rust the disposal out rather quickly.
You will need to get inside the wall to lower the drain pipe to do this correctly.
Lake County, Florida plumber
Springtime Plumbing Services, LLC
License #11067533
352-630-5673
phishfood is offline
People Like This
Old 03-07-2013, 04:33 AM   #3
IFIXH20
HERE TO HELP
Liked 192 Times on 157 Posts
Likes Given: 137
You may have another option --- going with a low / high sink ( one side shallow the other side is deep). The disposal might work on the shallow sink side.
IFIXH20 is offline
Old 03-07-2013, 11:41 AM   #4
johnjh2o
johnjh2o's Avatar
Liked 409 Times on 324 Posts
Likes Given: 258
It looks like it is on the high side. To the left of the disposal is a basket strainer that appears to be very close to the waste line height. As fish said it's time to open up the wall.
John
johnjh2o is online now
Old 03-07-2013, 11:01 PM   #5
IFIXH20
HERE TO HELP
Likes Given: 137
Good eyes John , I totally miss that.
IFIXH20 is offline
Old 03-13-2013, 02:02 PM   #6
RichG
I ended up calling a plumber. He ran a new line through the bottom of the cabinet and tied it into the old line in the basement. Here's a pic of the finished work:
RichG is offline
Old 03-13-2013, 02:23 PM   #7
johnjh2o
johnjh2o's Avatar
Likes Given: 258
That is totally wrong. He is trying to use the old line as the vent. There are two things wrong with that.
1- He has a horizontal vent below the flood rim of the fixture.
2- If the waste line should become plugged below the DBL san. Tee It will run into the line that has become the new vent.
The correct way was to connect the new waste line to the vertical line in the wall.
John
Old 03-13-2013, 02:40 PM   #8
stevemachine
stevemachine's Avatar
Liked 90 Times on 78 Posts
Likes Given: 92
John
If he would have put a c.o on the flat vent then in my area that would be considered right however there's no c.o so yeah if it backs up it could plug itself off. I agree that the the best would've been to go in the wall and lower it but depending on the circumstances of how easy it is to get into the wall. He did cap off the old line right? Otherwise if it rains you may have some water coming in through the vent.
stevemachine is offline
Old 03-13-2013, 03:04 PM   #9
johnjh2o
johnjh2o's Avatar
Likes Given: 258
Quote:
I'm betting he did nothing with the old line and just cut a tee into the line in the basement and ran it up through the floor.
John
Old 03-13-2013, 03:25 PM   #10
stevemachine
Likes Given: 92
Good chance of that If he didn't put a c.o. On I'm betting he missed that too
fork stuck in kitchen garbage disposal and unjammable blackcheetah General Plumbing Help 4 01-17-2012 01:34 AM
wiring new Waste King 8000 garbage disposal justabovemaine General Plumbing Help 3 10-27-2011 12:23 AM
Does a garbage disposal need it's own breaker? keith5523 Toilets and Sinks 5 10-14-2011 12:46 AM
Replace a Garbage Disposal jcraw General Plumbing Help 8 04-15-2011 06:56 AM
Garbage Disposal Smell? JeeperCreeper Drain and Sewer Cleaning 13 05-16-2010 05:39 PM
