Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Septic Tanks > Old Septic Tank Problem
Thread Tools Display Modes
Old 02-12-2013, 01:09 AM   #1
Eichhoernchen
Default Old Septic Tank Problem
I have an old concrete septic tank. I don't know much about septic tanks and this is the first house I have owned with one. I think it was installed when the house was built in the early 1950's. When I dug it up the lid is cast iron and about 24" by 48" and the hole into the tank is about 20" by 40" or so. I don't know if I have a second tank lid or just the one. I also want to be able to have access without digging it up but I don't know if I can install a riser conversion for it. Any advice would be of great help.
Eichhoernchen is offline
Old 02-12-2013, 01:20 AM   #2
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
It sounds like you have a old steel tank. There have been cases of people falling into those tanks because of the lids failing. It may be wise to have the tank pumped and have them checkout the lid. Hate to see some child fall into that tank. It can be very dangerous.
John
johnjh2o is offline
Old 02-12-2013, 02:56 AM   #3
Eichhoernchen
It might be steel, not too sure, however the lid itself is very heavy and it takes quite the effort to lift. I am having it pumped this friday. I am just wondering how I can make something so I get access to it without having to dig it up. Worst comes to worst, I will just build an access with blocks around and have a peaked lid so rain won't get it.
Old 02-12-2013, 04:13 PM   #4
speedbump
Wells & pumps; not a...
speedbump's Avatar
Liked 211 Times on 192 Posts
Likes Given: 46
I'm not sure why you want access, and you might be allowing some pretty foul odors to float out. Digging one up isn't a big deal, they aren't normally more than a foot or so deep.
I have never seen a cast iron tank, I have seen plastic, concrete and even 220 gallon oil drums used as tanks. I used a 55 gallon drum once at a hunting camp.
I agree with John, have it pumped, inspected and repaired if it seems dangerous.
speedbump is offline
Old 02-13-2013, 03:39 PM   #5
Eichhoernchen
I guess you're right, the time and expense would be a lot more than to simply dig it up every other year
floating septic tank IFIXH20 Septic Tanks 11 06-30-2012 12:45 PM
Septic tank question.. rtlplumbing Septic Tanks 2 03-21-2012 06:06 PM
How big is my septic tank? Mania64 Septic Tanks 5 05-25-2011 07:41 AM
Septic Tank Leak jmrardin General Plumbing Help 2 03-09-2010 12:57 AM
Newest Threads
