Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > Plumbers Putty Or Wax Ring?
Thread Tools Display Modes
Old 04-02-2010, 03:23 PM   #1
specgrade
Liked 5 Times on 5 Posts
Likes Given: 16
Default Plumbers Putty Or Wax Ring?
I just replaced 2 toilets and they didn't have wax rings, they had plumbers putty. I have always used a wax ring to set a toilet but now I'm thinking of trying the putty.
What are your thoughts?
specgrade is offline
Old 04-02-2010, 03:41 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1130 Times on 922 Posts
Likes Given: 350
For the inexpensive cost of the wax ring, I would not take a chance. It may work, but do you want to reset a toilet again in the near future if it doesn't work?
havasu is offline
Old 04-02-2010, 05:21 PM   #3
specgrade
Likes Given: 16
Quote:
I know what you are saying and no I wouldn't want to have to reset the toilet again. The old toilets were put in back in 1970 and lasted until I pulled them for more water saving ones. Forty years isn't bad for just plumbers putty.
Old 04-02-2010, 08:08 PM   #4
havasu
Administrator
havasu's Avatar
Likes Given: 350
The primary concern I see with using plumber's putty is because it shrinks, and becomes hard and brittle after time. You may not discover the slight leakage, but will end up corroding the flange after time. Wax will remain plyable almost forever, which would create an leakproof seal.
havasu is offline
Old 04-02-2010, 10:20 PM   #5
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
I have heard of this being done, but probably because I don't do much in the way of service work, have never seen it myself. I wonder if some of the service guys on here can comment.
phishfood is offline
Old 04-07-2010, 10:41 PM   #6
jimclemmer
hey
If you are sure that you wouldn't want to have to reset the toilet again then i suggest you to try the putty.
thanks
Regards
Jimclemmer
Hot Water Heater Replacement
jimclemmer is offline
Old 04-08-2010, 02:24 PM   #7
majakdragon
Plumbers putty is not made to withstand any pressure. Should you need to plunge one of the toilets, you may find yourself removing the toilet again. Plumbers putty also contains oil which could bleed out and stain the flooring around the toilet base.
If you have never made a mistake, you probably haven't done much.
majakdragon is offline
Old 04-17-2010, 02:18 PM   #8
majakdragon
Wax seals. You will not find sealing a toilet on the uses stated on the Plumbers Putty container.
Old 04-17-2010, 07:19 PM   #9
donald1
Quote:
i think u r right.it means wax is better than putty.
donald1 is offline
Old 04-23-2010, 06:57 PM   #10
specgrade
Likes Given: 16
It does say " For setting bowls, fixtures, sinks, frames and strainers. Will not crack, separate, crumble, harden or shrink."
Isn't a toilet considered a "fixture"?
Tags
plumber's putty, wax, ring, toilet
Flange/wax ring Dogstar Toilets and Sinks 2 06-29-2012 11:56 PM
O ring kits, which one and where? phishfood Plumbing Products 3 06-05-2012 11:46 AM
wax less ring issue ishouldacalledaplumber General Plumbing Help 1 04-20-2012 03:24 PM
Plumbers Putty on plastic index1489 General Plumbing Help 1 03-22-2012 01:26 PM
Installing wax ring havasu Toilets and Sinks 4 10-19-2011 02:50 AM
Newest Threads
