Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Drain and Sewer Cleaning > How to prevent food residue build-up and clog
Thread Tools Display Modes
Old 01-27-2013, 05:36 AM   #1
q0987
Liked 1 Times on 1 Posts
Default How to prevent food residue build-up and clog
Hello all,
I have regularly cleaned the pipes down the kitchen sink. But it gets clog very quickly. I end up turning on the garbage disposer to speed the drain.
The food residue always clog in the tip of main protruding pipe(green circle) and then slowly build-up. When clean those pipes, I have leveled the main pipe.
Is there any good advise so that I can avoid such a thing happen?
Thank you
q0987 is offline
Old 01-27-2013, 06:33 AM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
Well you don't want anything level in a drainage system and that could be part of your issue. Grade at 1/4"/ft in this situation. Also are you running water while you auger. What I've found is once you get the blockage clear, enough to drain, run water until it either backs up again or run water continually and auger. What size head are you using? You should use minimum 1" head on this line. And something that's gonna help as well is an enzyme as preventative maintenance. It eats away gunk and sludge and will leave behind a non stick film so other stuff won't stick to it. Also another tip is I usually don't use a tip, just end up bending the tip of the cable and it acts as a whip. That usually cleans the lines quite well in my opinion, but don't do that unless you own the equipment.
stevemachine is offline
Old 01-27-2013, 06:34 AM   #3
stevemachine
Likes Given: 97
And also make sure you're using a powered auger. Makes a huge difference
Old 01-27-2013, 12:46 PM   #4
johnjh2o
johnjh2o's Avatar
Liked 692 Times on 526 Posts
Likes Given: 580
You may not be running enough water when using the disposal. Turn the water on before you start the disposal and let it run a little longer after the food waste is gone.
John
johnjh2o is offline
phishfood Likes This
Old 01-27-2013, 02:13 PM   #5
q0987
Quote:
Yes, we always run the water while turn on the disposer. However, we should run the water/disposer a little longer and we will do!
Question 1> Please see the size of my pipe. Any issues?
Question 2> Please see whether or not I can tilt the main pipe?
Will it damage the pipes in a long run and cause leakage since the lift will cause stretch.
Question 3> Please tell me where I can buy the enzyme and how I can place it?
Thank you
q0987 is offline
Old 01-27-2013, 02:22 PM   #6
phishfood
Liked 936 Times on 752 Posts
Likes Given: 1672
That is 2" pipe, which is the standard size for kitchen sink drain lines.
It should be safe to gently raise the drain pipe to provide some fall on the piping.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Old 01-27-2013, 02:34 PM   #7
Caduceus
Caduceus's Avatar
Liked 348 Times on 254 Posts
Likes Given: 230
Also note that the disposal p-trap, as well as the twin-wye to the disposal, has back fall. It will require a new install of the twin-wye to get good flow to the drain.
Caduceus is offline
Old 01-27-2013, 05:47 PM   #8
q0987
Quote:
Do you have a good installed pipes in real image to illustrate this?
Thank you
q0987 is offline
Old 01-27-2013, 09:01 PM   #9
stevemachine
Likes Given: 97
You can buy enzyme from Home Depot or any big box store. Follow directions on the bottle. Usually you some in the drain and let it sit for a while. But like said before you need to correct the grade issue first
Old 01-27-2013, 09:41 PM   #10
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Beside the drain , I would check the disposal grinder blade to make sure the waste is being broken down proper, if the blade has notches in it large pieces of waste can get in your drain. using a flashlight look into the disposal to see if you see any notches in your blade pay close attention to the blade edges (do not turn disposal on while checking).
IFIXH20 is offline
Tips Cleaning Food Clogged Pipes? KenO Drain and Sewer Cleaning 8 08-21-2012 02:00 AM
I have an underground p trap for my tub, how to prevent it from freezing? amodoko General Plumbing Help 5 12-25-2011 02:46 AM
How to prevent pipes from freezing when there ouside ZiggyCS General Plumbing Help 2 09-01-2011 11:34 PM
Local Fair Junk Food Mr_David General Discussion 17 07-06-2011 03:43 PM
Sulfur odor, black residue in toilets. BringingChaos General Plumbing Help 6 04-13-2011 01:19 PM
Newest Threads
