Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > pipe corrosion on w/h intake
Thread Tools Display Modes
Old 01-26-2013, 09:42 PM   #1
olduglyguy
Default pipe corrosion on w/h intake
I have a spigot that turns the cold water on to the water heater and the spigot has corrosion to where I cannot turn the valve. Should I be concerned? This is a new house that I just purchased and the w/h was replaced about 2 yrs ago.
olduglyguy is offline
Old 01-26-2013, 10:50 PM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
Well you should be ok for now but I wouldn't let it go too long. If there ever were an emergency with the water heater you would have to shut the whole house down. If that valve worked at least you only have to isolate the hot side if there are issues with the tank. Or the valve itself could start leaking. Hard to say really cause we can't predict. If it was house I'd get it fixed, as long as I could afford to, or soon as I can afford it I'd do it. It shouldn't cost you too much to have it replaced, they will have to shut down the whole house to replace it. Probably around 1 hr for actual work. Have you checked your main water shut off in the house? If it doesn't work well you could do them both in one shot. I would get a 1/4 ball valve if they put a new valve in. They are practically maintenance free and won't seize up or at least a lot less likely.
stevemachine is offline
Old 01-27-2013, 09:16 PM   #3
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
Quote:
If your home came with a home warranty I would have it replaced right away, and like Stevemachine said, I would definitely check the service entrance valve (house main water valve) for proper operation.
IFIXH20 is offline
American Standard fresh air intake? DrWhatsHisName General Plumbing Help 1 05-22-2012 11:16 PM
Will a water softener protect from corrosion in pipes? Arrowman Water Heaters and Softeners 2 10-05-2011 11:27 PM
Toilet PVC drain pipe came loose from pipe that leads to sewer. tireshark General Plumbing Help 6 08-02-2011 01:20 AM
Need to cap off an iron water pipe 3/4 for renos, do I need to thread the pipe? drchalifax General Plumbing Help 1 05-20-2011 09:04 PM
Sewer Pipe Replacement - liners vs pvc (aka pipe bursting) 914 General Plumbing Help 10 08-19-2010 01:07 AM
Newest Threads
