Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Putting outside water tap in
Thread Tools Display Modes
Old 01-24-2013, 06:46 PM   #1
Markcowie
Default Putting outside water tap in
Could you suggest the tools I will need to do this job ?
Markcowie is offline
Old 01-24-2013, 09:58 PM   #2
stevemachine
stevemachine's Avatar
Liked 115 Times on 99 Posts
Likes Given: 97
Copper or pex? Replacement or new install? A few more details and we can surely help ya out
stevemachine is offline
Old 01-25-2013, 06:29 PM   #3
Markcowie
It's copper pipes I am at college doing plumbing course and this is my little project cheers
Old 01-25-2013, 06:31 PM   #4
Markcowie
Also it's a install I know you need to drill from outside to stop brick crumble ?
Old 01-25-2013, 06:38 PM   #5
stevemachine
Likes Given: 97
Copper cutters, grit cloth, tape measure, torch, flux, solder (95-5 or 97-3) and drilling from the outside seems about right. Every situation is a bit different but what I do solder a piece of copper into the hose Bibb, plenty long. Make sure the valve is open when you solder so you don't melt the washer. Then once the hole is drilled I put the hose Bibb with a soldered piece of pipe through the hole. If you have to drill pilot holes for your screws mark those out and drill them, then reinsert the hose Bibb and measure mark cut clean flux and connect then go back outside, make sure the Hose Bibb is level and screw it in to your holes. Again make sure the hose Bibb is open an solder.
Old 01-26-2013, 07:27 PM   #6
DFBonnett
Liked 17 Times on 14 Posts
Likes Given: 22
FWIW, go to YouTube and search hose bib.
DFBonnett is offline
Newest Threads
