Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Project Display > Replacing Cast Iron Water Closet Flange
Thread Tools Display Modes
Old 04-01-2010, 02:04 AM   #1
Mr_David
Easily Amused
Mr_David's Avatar
Liked 895 Times on 726 Posts
Likes Given: 593
Default Replacing Cast Iron Water Closet Flange
I'm going to show you how I replaced a cast Iron closet flange using lead wool and oakum.
The Lead wool gets packed into the joint rather ten melting and pouring it in.
Much safer this way.
" Use protective Gloves when handling The Lead wool."
This particular flange was about 1" below the finished floor and required at least 3 wax seals to set the toilet.
I'm going to raise the flange flush to the finished floor.
Normally the top end of the cast iron closet bend would also be flush with the floor.
A standard cast iron flange has only 2" of depth. For this job I used an extended hub Flange.
There are other methods of installing a new flange onto a cast Iron closet bend.
There are products that use a neoprene seal and just bolt on but I have had my share of replacing those so called easy fixes.
This is not an easy fix but it will not come loose if done right.
a.k.a. Krazedav
Mr_David is offline
Old 04-01-2010, 02:08 AM   #2
Mr_David
Easily Amused
Mr_David's Avatar
Likes Given: 593
To remove the old flange I drilled out the lead.
Be careful.
The flange hub is tapered and you can snap a drill bit.
Sometimes the existing lead seal is narrower on one side.
The closer together you can get the holes the easy it is to dig out the lead.
Now that all or most of the lead is removed the flange should just lift out.
This one I had to chip a little concrete from around the edges to remove
a.k.a. Krazedav
Mr_David is offline
Old 04-01-2010, 02:13 AM   #3
Mr_David
Easily Amused
Mr_David's Avatar
Likes Given: 593
Set the new flange. It can be slightly above the finished floor, but to much and the toilet wont sit on the floor properly.
pack the oakum into the hub. 1/2" minimum (packed tight)
Try to keep the gap between the pipe and the flange even.
You will have to hold the flange up in place while packing the oakum.
You can install the closet bolts and a couple strips of wood to hold it flush to floor until its tight.
a.k.a. Krazedav
Mr_David is offline
Old 04-01-2010, 02:16 AM   #4
Mr_David
Easily Amused
Mr_David's Avatar
Likes Given: 593
I poured Rapid Set concrete in the space under exterior of flange after I installed the oakum.
The flange has a tendency to shift a little when packing the Lead wool.
You thought drilling it out was hard.
Now you start packing the lead.
Use a caulking iron. You can use an old narrow chisel or screw driver , Just grind the end flat.
Pack it tight in approx 1/2" increments. Over pack it above the end of the pipe.
Then scrap it flush to the top of the pipe.
a.k.a. Krazedav
Mr_David is offline
Old 04-01-2010, 02:18 AM   #5
Mr_David
Easily Amused
Mr_David's Avatar
Likes Given: 593
Normally the pipe, the lead seal and the flange are flush. This combined flush surface it where the wax seal is going to sit.
This repair needs that area filled in.
I used a short piece of 4"ABS pipe and plumbers putty to fill in the gap.
You could use more Lead Wool instead of the putty,
But after packing the flange you're probably thinking " It's time to wrap this up, set the toilet and go.
You should always install new bolts to the flange with a washer and nut.
a.k.a. Krazedav
Mr_David is offline
Old 04-01-2010, 08:07 PM   #6
BRad704
Moderation
BRad704's Avatar
Liked 6 Times on 6 Posts
I can say with 100% certainty that I have learned something new today! Great looking work!
- brad - Official PF mathamagician & knower of the low down -
Quote:
Originally Posted by Austin
I loved that goat.
Quote:
Originally Posted by Chris View Post
Three more and I am on top.
BRad704 is offline
Old 04-01-2010, 08:44 PM   #7
havasu
Administrator
havasu's Avatar
Liked 1130 Times on 922 Posts
Likes Given: 351
I also learned from this. What I was wondering was how long has it been since the old melted lead pots were used?
havasu is offline
Old 04-01-2010, 09:18 PM   #8
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
Great write up thanks. I have wondered how this would be done and now I know.
Chris is offline
Old 04-02-2010, 03:13 PM   #9
specgrade
Liked 5 Times on 5 Posts
Likes Given: 16
Now that was a great post. It looked like hard work but the results are a vast improvement!
Thanks for the lesson!
specgrade is offline
Old 04-02-2010, 10:16 PM   #10
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
Thanks for posting this! I have never tried to replace one, but at least now I have some idea how to go about it.
You mentioned having had trouble with the boltdown PVC/neoprene replacement flanges. These are what I have used the time or two that I have run into this. What types of problems do you see with those?
phishfood is offline
Tags
water, flange, cast, iron, lead wool, packing
Can I glue a PVC flange to a cast iron sewer pipe? Gastronomique Toilets and Sinks 4 01-04-2012 10:39 PM
Need Help-- New Closet Flange to Old Iron Pipe fireduck Toilets and Sinks 4 11-28-2011 01:54 PM
closet flange Dave43026 Toilets and Sinks 1 11-07-2011 02:24 PM
replacing cast iron radiator supplys WilliamBonetto General Plumbing Help 1 07-26-2010 04:37 PM
How do I replace a cast iron flange? catpace Toilets and Sinks 2 07-01-2010 02:13 PM
Newest Threads
